Recovered a center quarter corner yesterday. I'm not certain to the pedigree and was a bit stumped as how to describe in notes. Never seen one quite like it before. Appears to be a 2 1/4" iron/steel shaft with what appears to be a 1" I.P. either welded or cast into the main shaft and looks like it might have been filled with grout. Appears if there was a cap on it at one time but was sheered off. Very stout monument. In any case I've never seen one like it before. My best guess is it was set some time in the '60s-'70s? Anybody out there know what it is? Maybe a drive shaft of some sort?
I'm going to guess that it's an axle, or at least part of one.
T. Nelson - SAM
A drive shaft would be solid, not filled with grout. My guess is it is a steam union collar flange fitting.
Go to Ezekiel. It's that elusive "Wheel within a wheel".
Not being able to get a set of fingers on it, I'll throw out the guess, is it maybe a 1" pipe set in concrete inside the 2 1/4" pipe? I know you say it appears welded, but I'm chunking ideas here.
Monte, post: 408974, member: 11913 wrote: Not being able to get a set of fingers on it, I'll throw out the guess, is it maybe a 1" pipe set in concrete inside the 2 1/4" pipe? I know you say it appears welded, but I'm chunking ideas here.
That's what I'd call it. 😉
During the Alaskan Gold Rush, of the 1896-1899, all kinds of schemes were hatched to extract GOLD from them thar hills.
ALL kinds of "Stuff" was left behind, from this event. I think there was alot of scrap metal left up there. And, that scrap metal, BECAME survey monuments, as needed.
So, my "creature of last resort" is to "Literally Describe" a monument.
My instinct would be to dig around that "Thing" you have above, and concoct a description.
Something like "found 1-3/4" dia steel pipe, with concrete inside, and a 3/4" steel pipe, centered inside, all filled with concrete"
This way, ANY other later surveyor who comes your way, will have an ACTUAL description of it.
Thus, a Rebar is:
"found 1/2" dia, steel shaft, with ribs, spaced in a regular hatch pattern, and protruding 2" above a mossy covered forest floor"
I am writing that, to describe how a non initiate to rebar, would apply the principle.
If I PULL the monument, then I also get it's length, and any other descriptive items.
I did one one time that was about like this:
"Found 3/4" pipe, with street elbow on top, and pounded so that top shows indentations."
This makes my "find" into a part of the record, and individualizes the monument alot.
[INDENT]
[/INDENT]
That was my original assumption until I used a rock hammer to try cleaning it up and found the base to be solid metal, not filled pipe, which led me to suspect a drive shaft, but the 1" pipe on top had bit of grout in it which is more akin to what GLO set early in the century. Got me curious. At -16F I'm not about to try chipping it out any deeper.
It's a pink flag holder.
What is it called in the document that you used to determine it to be recovered?
I had copies of a local surveyors notes from 1937 and he called for wine bottle 2' below grade with a tack in the cork at the radius point of a cul-de-sac. After some very careful digging it was there. (Did not check to see if bottle was full though :D:D)
Call it what it is...
2 1/4" dia. steel monument w/protruding 1" dia. steel top.
It looks like it may be a portion of an old driveshaft. They were fairly flimsy things in the early days.
It's a goat stake, not a monument, rookie.
ropestretcher, post: 408996, member: 2059 wrote: What is it called in the document that you used to determine it to be recovered?
Whoever set the center 1/4 didn't leave a record, not that I've found anyway. Fairly common around here with survey work done in the 50's-70's. I have several plats and records of survey that accepted it going back to the early 1980s and as recently as last year. Some call it a found 2" IP, though it is not. I haven't broken down the section to determine how close to perfect the position is, but it's apparently been long accepted, I just don't know what it is, but suspect something salvaged from a bone yard, which was common practice at the time, or some kind of unique bomb proof monument that just never caught on like a 'copperweld' or a 'Grizzly'. I don't know if 'Grizzly' were ever used anywhere but here, but a 'Griz' is a small 1/2" wide angle iron that originally came with a small plastic button cap. Rarely find the caps as the plastic just didn't hold up. See a few of those on older 70's subdivisions.
TJE Yogi, post: 409008, member: 963 wrote: It's a goat stake, not a monument, rookie.
Thanks. Very helpful.
Goat stakes weren't generally grouted. Possibly just a dog stake...a lot lower on the "order of calls" hierarchy...;)
Concur with those suggesting you describe what you see. The problem with finding a correct name for such a thing does not mean that anyone else has any idea what that means. Saying you found a burmuzler doesn't help anyone.
I must concur with Holy Cow and admit that I am not seeing enough of the object.
That could be a roller bearing around a pipe.
It could be a small perforated pipe inside a larger pipe, aka spark resistor muffler or silencer
It could be the remains of a government monument
I too concur with the divine bovine and others; whatever it was in it's prior life - axle, drive shaft, etc. it is that no longer. Those items are defined by the character of their use rather than their material nature. It's now a hunk of metal and grout that occupies the position of a property corner...it's a 2 1/4" diameter metal and grout monument.
Describe it as you wish and if you don't find any contradictory evidence I would call it good. 😎
