What is it (property corner)?
32 Users
captain caveman
(@captain-caveman)
I located this as part of a boundary survey but unfortunately, not sure what it is. Haven't done a whole lot of rural boundary surveys. Can anyone help a greenhorn?
Posted : January 24, 2011 9:50 am
Looks like part of an old axle. Is it called for in an old survey?
Posted : January 24, 2011 9:55 am
carl-b-correll
(@carl-b-correll)
What is it described as? How big is it?
I might call it a "cupped-up iron (pipe)- 4" (or whatever) O.D. found by a chainlink fence post."
Does it fit the calls?
surv8r
(@surv8r)
Looks like an old axle housing...
I can explain it to you, but I can't understand it for you...
Posted : January 24, 2011 10:09 am
Ed
 Ed
(@ed)
In my neck-o-the world it's a 2?, 3" or whatever open top pipe. Though it's plainly not. Looks something like an old drive shaft? No matter what you 'call' it your bearing and distance to it is what is going to matter the most. Plus, what was called for there in the deed or plat you're following? If it's like it is around here the description most likely calls for a 'point'.
Take care,
Ed
Posted : January 24, 2011 10:11 am
Kris Morgan
(@kris-morgan)
Wagon Thimble. We found one destroyed just the other day.
Posted : January 24, 2011 10:15 am
Probably waggon thimble.
I'd call it a Weird Metal Pipe, and post a pic on the plat!
Posted : January 24, 2011 10:20 am
surveysc
(@surveysc)
Looks like part of a farmer's disc to me.
Posted : January 24, 2011 10:33 am
Kris Morgan
(@kris-morgan)
Terry
That doesn't look like any disc I have in my barn or have ever seen. I will say that it MAY resemble the part of the feeder where seed drops down out of a hopper as used on a Seed Drill or Seed Planter, but that's about as close to a disc as I can get amigo.
Posted : January 24, 2011 10:46 am
The metal looks too thick, but otherwise it reminds me of the cover on a telescoping PTO shaft to power machinery from a tractor.
Posted : January 24, 2011 10:51 am
Axle Housing
Also include the uniform diameter of housing plus "with bell".
Posted : January 24, 2011 11:00 am
Kris Morgan
(@kris-morgan)
Bill
You're right. That metal is too thick for the slip sleeve on my bush-hog drive shaft or on the finish mower, but definitely looks right, I'll give you that one!
:beer:
Posted : January 24, 2011 11:31 am
RFB
 RFB
(@rfb)
It's a piece of scrap.
SET A PROPER MONUMENT NEARBY.
Posted : January 24, 2011 11:44 am
Wagon thimble
Posted : January 24, 2011 11:51 am
jud
 jud
(@jud)
What ever it is, it has been disturbed by the digging of the hole for the concrete and steel post. Unless it fits well I probably would not hold it but I would note its location on the record of survey. Don't believe it is a wagon thimble, at least not like any I have seen.
jud
Posted : January 24, 2011 11:53 am
Dave Ingram
(@dave-ingram)
Oh come on guys - it looks like the top of ....
an old hand pump for a well.
Posted : January 24, 2011 11:56 am
A typical "bell housing" on the end of an early model axle case.
Posted : January 24, 2011 11:58 am
Perhaps a 1932-1939 Packard Twelve?
Posted : January 24, 2011 12:44 pm
Hawkins LS 7973
(@hawkins-ls-7973)
Looks like a torque tube, maybe a model A?
Ty Hawkins
Posted : January 24, 2011 12:52 pm
