Apparently what I thought was a touchscreen issue is actually something wrong with the main board. And it can't be found to be replaced.
Soooooooo.
Anyone have a contact that might know about the Topcon FC2000 to verify what I'm being told?
Or, does anyone know of another collector that can run Topcon Hiper Pros?
Is there an app for that yet??
Andy
I'm running TDS survey pro on a nomad, no complaints
With your Hiper Pro, are you using base/rover? Or as a network rover? Both?
Did you check ebay? I've had decent results replacing DC's bought on ebay. You can usually tell from the pics and description if it is being sold by a surveyor who cared for the unit vs. a "pawn shop" reseller. Much cheaper than fixing.
Base and rover.
Thanks. I just wanted to mention that I've had no luck getting a Hiper Pro to work on the FDOT network with Survey Pro, but it works with SurvCE. I don't know if you are considering either as a replacement DC, but either should work as a base/rover.
