Trimble TSC3 Pictures
mlove5648
(@mlove5648)
Our field crew located column footers using our TSC3 Data Collector and took pictures. These pictures are linked to the shot numbers in TBC. Is there a way to print the pictures showing the shot numbers? If not, is there a software that you can use to quickly attach all the pictures and designate a point number text description under each picture?
Posted : July 27, 2017 11:38 am
kabonski
(@kabonski)
In Trimble Business Center you can create a custom report that will print the point number and any info you want along with any corresponding numbers.
Posted : July 27, 2017 5:24 pm
It seems to me that if you spend $400MM on these software programs there has to be a way to link an on-screen point entity to a meta file in the job directory where hovering over that point would instantly list some of the attributes or linked files of that point.
Posted : July 27, 2017 5:45 pm
