Trimble 5600 power rod
SWAG
 SWAG
(@swag)
Guys, where are you getting your power rod batteries replaced at? I see that 15 different companies offer the service. Is one better than the other?
Posted : January 20, 2015 7:50 am
DEREK G. GRAHAM OLS OLIP
(@derek-g-graham-ols-olip)
Try: http://www.batteryrevival.com/
Posted : January 20, 2015 4:21 pm
Norman_Oklahoma
> Try: http://www.batteryrevival.com/br >
I second that. They did good work for us.
Posted : January 20, 2015 5:37 pm
PINOST
(@pinost)
HI
as you guys went through this already
can you just get a normal prism pole and add the power stick to it ??
Posted : April 16, 2015 5:06 pm
Norman_Oklahoma
Sure. It just has the ordinary 5/8"x11 threads at both ends. Only a couple of problems - the measure up scale on the side will be all but meaningless, and the rod won't retract all the way. 2 feet of battery will be sticking out. Your lowest possible rod ht will be about 7'.
Posted : April 16, 2015 5:18 pm
Attila Varadi
(@attila-varadi)
Hi,
Does anybody have any idea how to disassembling the Power Rod to replace the battery cells inside?
Thank you in advance!
Posted : July 1, 2018 5:11 am
mike1202
(@mike1202)
I am also interested in how to disassembling the Power Rod to replace the battery cells.
Posted : July 6, 2018 2:18 pm
Norman_Oklahoma
The people at batteryrevival.com do.
Posted : July 6, 2018 7:35 pm
Attila Varadi
(@attila-varadi)
Thank you for the tip, however i live in Europe so this Will not work now. 🙁
Posted : July 8, 2018 3:21 pm
