On November 15, I ran two simultaneous GPS log sessions using Trimble 4000SSi receivers. The two sessions were on the same project, at the same site, with similar open view of the sky. However, the resultant observation files show that one of the sessions was characterized by high PDOP values, whereas the other was not, and I am looking for suggestions as to why that might be. Perhaps it is a result of a setting on the receiver?
The headers from each of the RINEX files are below:
THE "BAD" FILE: (7 SATELLITES TRACKED)
2.11 OBSERVATION DATA GPS(GPS) RINEX VERSION / TYPE
cnvtToRINEX 2.11.0 A. R. Thorp 22-Nov-11 03:48 UTC PGM / RUN BY / DATE
----------------------------------------------------------- COMMENT
POINT 2001 MARKER NAME
3828 MARKER NUMBER
A. R. Thorp ACCORD Engineering & Surveying, LLC OBSERVER / AGENCY
13828 Trimble 4000 SSi 7.29 REC # / TYPE / VERS
00044631 TRM22020.00-GP ANT # / TYPE
1376327.4170 -4520123.1371 4270561.8093 APPROX POSITION XYZ
1.4905 0.0000 0.0000 ANTENNA: DELTA H/E/N
1 1 0 WAVELENGTH FACT L1/2
6 C1 L1 L2 P2 S1 S2 # / TYPES OF OBSERV
2011 11 15 15 45 45.0000000 GPS TIME OF FIRST OBS
2011 11 15 18 15 15.0000000 GPS TIME OF LAST OBS
0 RCV CLOCK OFFS APPL
15 LEAP SECONDS
7 # OF SATELLITES
G01 175 175 175 175 175 175 PRN / # OF OBS
G02 295 295 291 291 295 291 PRN / # OF OBS
G04 599 599 599 599 599 599 PRN / # OF OBS
G09 307 307 304 304 307 304 PRN / # OF OBS
G10 433 433 425 425 433 425 PRN / # OF OBS
G17 599 599 599 599 599 599 PRN / # OF OBS
G20 459 459 459 459 459 459 PRN / # OF OBS
CARRIER PHASE MEASUREMENTS: PHASE SHIFTS REMOVED COMMENT
END OF HEADER
THE "GOOD" FILE: (15 SATELLITES TRACKED)
cnvtToRINEX 2.11.0 A. R. Thorp 22-Nov-11 03:44 UTC PGM / RUN BY / DATE
POINT 2000 MARKER NAME
3809 MARKER NUMBER
13809 4000 SSi 7.29 REC # / TYPE / VERS
0220044459 TRM22020.00+GP ANT # / TYPE
1376185.8824 -4520026.1793 4270716.3069 APPROX POSITION XYZ
1.5180 0.0000 0.0000 ANTENNA: DELTA H/E/N
2011 11 15 15 26 15.0000000 GPS TIME OF FIRST OBS
2011 11 15 18 31 0.0000000 GPS TIME OF LAST OBS
15 LEAP SECONDS
15 # OF SATELLITES
G01 257 257 255 255 257 255 PRN / # OF OBS
G02 479 479 476 476 479 476 PRN / # OF OBS
G04 740 740 740 740 740 740 PRN / # OF OBS
G05 58 57 54 54 58 54 PRN / # OF OBS
G09 330 330 312 312 330 312 PRN / # OF OBS
G10 494 494 484 484 494 484 PRN / # OF OBS
G11 85 85 85 85 85 85 PRN / # OF OBS
G12 350 350 346 346 350 346 PRN / # OF OBS
G13 101 101 96 96 101 96 PRN / # OF OBS
G17 740 740 740 740 740 740 PRN / # OF OBS
G20 538 538 535 535 538 535 PRN / # OF OBS
G23 155 154 151 151 155 151 PRN / # OF OBS
G25 48 48 43 43 48 43 PRN / # OF OBS
G28 516 516 516 516 516 516 PRN / # OF OBS
G32 289 289 287 287 289 287 PRN / # OF OBS
END OF HEADER
I had a somewhat similar problem with a Trimble 4000se many years ago. It turned out that one of the two antennas that I had received with the unit (used), had a “sector” in it, and didn't track birds in that particular “quadrant” (a rough and probably inaccurate description of the problem).
Several years ago, I received some data from a Surveyor in Utah that had similar “weirdness,” (Trimble Compact L1/L2). A quick test indicated that the antenna in question was simply NOT tracking birds within a particular “zone” (sector/quadrant). When a given [tracked] bird entered that “zone,” it “went away,” only to reappear an hour or so later once it had passed through the “dead zone.”
I dunno enough about GPS antennas to say anymore than that, but it's something that I would check out (AFTER checking the “mask angle” that might be set in the receiver of course).
Your planning software might also give you a clue IF this is the problem.
Wow that's interesting. I will check to see if this pattern exists when using either of my two antennas. Yes, they are Compact L1/L2 by Trimble, one with groundplane and one without. Thank you, Loyal!
I've looked at my RINEX files to see if I could find any pattern. The number of satellites tracked varies by job from 7 to 15, typically around 11 for a 2.5-3 hour log session.
I've only used that particular receiver (#3828) in conjunction with the particular antenna (the one without groundplane) ONCE, so I have nothing direct to compare to. I have used the 3828 receiver at another job with my other antenna (with groundplane), and it tracked 10 satellites on that job.
I have used other receivers with the suspect antenna (without the groundplane) on a few jobs, and the resulting log sessions show between 10 and 13 satellites tracked. This session, resulting in only 7 satellites tracked, appears to be an aberration.
I checked each of my receivers, and the mask angle varies between 10 and 13 degrees.
Howdy,
I'd test the hypothesis that it is a bad "sector" by using the "sky plot" feature in planning software. The Trimble software includes this feature. There are also web sites with this feature. As you have data observed at two sites during the same time interval, differences in SVs tracked should be examined to determine the cause. Obviously, if all the SVs missing are in the same quadrant/area of the sky, you have a clue.
For this test to work you should have oriented your antennas to north. While an antenna problem could be the problem, did you monitor the site during observations? If someone or something interfered with the signal coming to the antenna the problem could also occur. This may be a more likely answer if the problem is intermittent. Of course electronics are notoriously perverse when attempting to determine reasons for failures,
HTH,
DMM
Are these files from the same rec'r or different?
If different, what are the elevation masks set at? If different then that may be the culprit. Some of the data is being screened off by the mask, i.e. 15 degree vs. 10 degree.
yeah, get rid of the elevation mask altogether.
DMM,
Thanks. I'll see if I can find the sky plot software. I recently acquired TBC software, so maybe that has it.
As for orientation of the antennas, one of the antennas has the groundplane, and was properly oriented to north during the session. The other antenna is without the groundplane and was the one which only tracked 7 satellites. It was not oriented to north, as I have found no markings thereon which would indicate how it should be oriented. I'll look into that further.
Al
> Howdy,
> HTH,
> DMM
Two different receivers, run simultaneously. Each of the two receivers had identical mask. +13 degrees.
I've reset the receivers to default setting which is +10 degrees mask.
Howdy,
I found a web-based tool that generates skyplots on the Ashtech site. It is a Beta version: http://asp.ashtech.com/wmp/ My data input is shown in this link: http://asp.ashtech.com/wmp/#tab5
Using the extracts of the RINEX file in your original post, I used the ECEF coordinates to compute geodetic coordinates. They indicate a location near Becket, MA at N42-18-04, W073-03-59. The two sites are about 231 meters apart. Google Earth shows it to be a densely wooded area.
I used these geodetic coordinates and the date and times shown as GPS Time in your posting as input into the linked tool. Here I encountered some problems.
De-selecting all GLONASS, SBAS and Galileo SVs and without specifying an elevation mask, I do NOT get a plot with all the SVs you logged. The plot shows only the following SVs: 1,4,8,11,17,20,27,28 and 32.
Looking at the plot generated does not show that the differences in satellites tracked to be due to their position in the sky relative to the site. Of course, the plot does NOT include all the SVs you show.
Possibly my problem is a bad XYZ value in the extract posted and therefore a wrong value for the station location. The starting location does NOT need to be very accurate with tens of miles not making a difference. Also the tool is a beta and may not have a current ephemeris.
Your Trimble software should include a mission planning module. The package is easy to use. It does require that you specify a current ephemeris.
HTH,
DMM
Is the firmware the same?
Try switching antennas and see if the problem "follows" the suspect antenna.
I'll check the firmware. Thanks for that idea!
used to be on trimble's site
It is probably still there. it is a stand alone program search Mission PLanning
I used Ashtech's Web Mission Planning software, as suggested, but my results are different, not sure why. I get many more satellites than you obtained. Thanks for the effort.
