Would anybody have these drivers for use with Window 10 64bit or Windows 7 32bit that they could send on to me please? info(at)jfpa.ie
Totalsurv, post: 431979, member: 8202 wrote: Would anybody have these drivers for use with Window 10 64bit or Windows 7 32bit that they could send on to me please? info(at)jfpa.ie
I would like them as well.
I have an xp machine for our hipers.
Sent from my SM-G930V using Tapatalk
Try this driver
Dropbox File (Private or Invalid)
;">Topcon_USB_Driver_v7_13.zip
It should work with WIndows XP, 7, 8, 10 see folders:
Windows 32 bit
Windows 64 bit
WinXP
leegreen, post: 432022, member: 2332 wrote: Try this driver
Windows 32 bit
Windows 64 bit
WinXP
Thank you works great, much appreciated. Would you have the serial drivers as well by any chance?
Totalsurv, post: 432035, member: 8202 wrote: Thank you works great, much appreciated. Would you have the serial drivers as well by any chance?
No need for serial driver's? They don't exist, and never have. Just plug 9 pin serial cable into to PC if you have one an set to com 1, 9600 baud, 8 nit, no paraty. Should work.
leegreen, post: 432041, member: 2332 wrote: No need for serial driver's? They don't exist, and never have. Just plug 9 pin serial cable into to PC if you have one an set to com 1, 9600 baud, 8 nit, no paraty. Should work.
I just tried that and it works. Many thanks again.
