Anybody have this setup? If so what are the benefits with optical surveying?
I did not think it was worth the additional 400-500$. The real problem happened when i went to hook to a gps receiver other than trimble. I had to reload survey pro without tsx to run a different brand of gps. Not sure about different brands of optical equipment. Jp
&g http://trl.trimble.com/docushare/dsweb/Get/Document-240477/022543-122_Survey%20Pro%20with%20TSX_TN_0705_lr.pdf
Thank You
I use trimble receivers and the only benefit I noticed was being able to export RTK vectors for adjustment.
Thank You
