Surveyor 2 to NIVO
5 Users
(@charlie-c)
I am trying to Bluetooth a Carlson Surveyor 2 to a NIVO 2M with no luck.
I called the Trimble Dealer I purchased the NIVO form and his comment was "its not our DC, can't help you".
Carlson tech support has tried several times with possible solutions, but none has worked.
I contacted the company I purchased the DC from and they say they can connect to a NIVO with no problem.
Has anyone else been able to connect the two?
Thank you
Posted : 07/01/2017 9:46 am
Four aught jumper cables. Duct tape, and bailing wire.
From my reading, i can see various equipment vendors, DELIBERATELY making little changes in their software, just to keep it proprietary.
When Trimble acquired TDS, it jump started this trend.
Posted : 07/01/2017 10:08 am
(@mike-mac)
Can you see each device from the other? If so are they pairing? If not is there a onoff switch for BT on one thats not on?
Posted : 07/01/2017 10:23 am
(@charlie-c)
Can not see NIVO on DC in Bluetooth.
Can see NIVO and works great with cable.
Posted : 07/01/2017 10:26 am
(@jwcole)
Charlie c, post: 407932, member: 6798 wrote: Can not see NIVO on DC in Bluetooth.
I would try turning Bluetooth off and then back on in the Nivo. I have a Carlson mini 2 and a Nivo 3.M, and they work great together with Bluetooth.
Sent from my SM-G930V using Tapatalk
Posted : 07/01/2017 1:01 pm
(@chopping_broccoli)
Connect to it using Windows CE first. Then attempt in SurvCE. I managed to get every datacollector I had to connect to my 3m but it took me the better part of a day and a Russian Youtube video to find the Bluetooth PIN for the Nivo.
Posted : 07/01/2017 2:33 pm
