State Plane Coordinate System of 2022
16 Users
shawn-billings
(@shawn-billings)
With the new geometric datum of 2022 coming, the need for new State Plane Coordinate System definitions is also on the horizon. Every surveyor who uses State Plane should get involved in this process. While it is still almost four years away, the changes are both technical, political and legislative, each requiring time to maneuver.?ÿ
Each State Plane Zone will be redefined for SPCS2022. The projection types used will be the same as used in SPCS83: Lambert Conformal Conic, Transverse Mercator, and Oblique Mercator. The Lambert Conformal Conic will be a single parallel rather than two parallel definition. From a functional standpoint, there is no difference between them. The single parallel is simpler to define, but can still be a secant (cutting into the ellipsoid) system if desired by making the k<sub>0</sub> (the scale factor at origin) less than 1.
SPCS27 zones were designed such that the grid factor would not exceed 1:10,000 (or 100 ppm). In the SPCS83 most zones inherited the same feature, although many States opted to reduce the number of zones which caused the zones to cover a larger geographic area with the consequence of higher grid distortion. It should be noted that this 1:10,000 distortion is only for the difference between ellipsoid distance and grid distance. Typically we do not work at either the ellipsoid or the grid, we work at the topographic surface (ground). The new zones will be designed to minimize linear distortion (the difference between grid and ground). There will still be distortion and for most, the distortion will need to be accounted for by users, but it should be less than it currently is.?ÿ
The NGS is also allowing "stake-holders" within a State to decide if they would prefer something other than a slightly enhanced version of the current SPCS, namely low distortion projections (LDP). Stake-holders are the State DOTs, State societies of surveyors and engineers, State-level GIS professionals. The stake-holders must unanimously decide to implement something other than the current SPCS or the NGS will implement the default slightly enhanced SPCS we currently have.?ÿ
In an NGS webinar by Michael Dennis on April 12, 2018, I was surprised when a poll was taken by participants of the webinar that asked what approach to the coordinate systems they preferred. If I recalled correctly, only about 25% of participants were interested in a low distortion projection approach.?ÿ
In my opinion we stand at an historic opportunity. We all know the difficulties that come with using the State Plane Coordinate System as it is currently defined. All projections have linear distortion. The SPCS often involves linear distortion that cannot be ignored. The remedies for this difference between a grid distance and a ground distance are seldom handled properly and require some overhead.?ÿ
Low distortion projections are designed such that the linear distortion between a grid inverse distance and a horizontal surface distance are within +/-25ppm and usually much better. This translates to a difference of only 0.025' in 1000'. In many cases this difference can be ignored. In cases in which this difference cannot be ignored, the same process for dealing with grid and ground distances can still be applied to LDP zones.
The greatest argument against the use of LDP's has been that the parameters for homegrown LDP's are not published. If the next State Plane System zone definitions are LDP's this becomes moot as the definitions will be codified. Survey software developers will have these definitions pre-loaded in their software. Likely, these LDP's, when properly designed, will cover several counties and follow county boundaries just like SPCS does now. If you know what county you are working in, you will know what LDP to select (just like you do now).?ÿ
I've been engaged with my State society for several months now regarding this and hope to encourage members to advocate for LDP for 2022. I encourage you to do the same in your State. If you are a surveyor in Texas, I'd love to hear from you, whether you agree with me or not.
Posted : April 14, 2018 2:01 pm
'If you are a surveyor in Texas, I'd love to hear from you, whether you agree with me or not.'
No .. just the field crew. Why are we doing this again ? Is this in regards to the tectonic plate shift those people on the left coast have to compensate for ? and why did we pick the planar instead of secant model ??ÿ
If this does go through, is it possible TPTB include a wholly recognizable new false N & E so we don't have to play a bunch of buckethead coordinate games with downloaded coordinate files ?
?ÿHonestly Respectfully,
~the field crew~
Posted : April 14, 2018 3:35 pm
Gene Kooper
(@gene-kooper)
Posted by: Shawn Billings
I do not ever recall seeing this as a design factor in the NAD27 SPC definitions.?ÿ Not that I doubt you, but can you provide a reference?
What I do recall is that for the UTM system, the scale factor of the Central Meridian was chosen to be 0.9996 to keep the grid distortion below 1:10,000 within each zone.
Posted : April 14, 2018 3:56 pm
I recall it being .9994 for my WYEC (TM)?ÿor something like that. I can look it up, but then I'd have to look at that blue book again.
Posted : April 14, 2018 4:21 pm
jaro
 jaro
(@jaro)
I want two things.
1) Grid North is still Grid North
2) None of the coordinates go over 9,999,999.99
Posted : April 14, 2018 4:58 pm
Glenn Borkenhagen
(@glenn-borkenhagen)
Posted by: Gene Kooper
Check NOAA Manual NOS NGS 5 State Plane Coordinate System of 1983 by James E. Stem, a PDF of which is available for download from the NGS web site, specifically the pages numbered 1 and 2 on the bottom.
GB
Posted : April 14, 2018 7:08 pm
Glenn Borkenhagen
Posted by: MightyMoe
You need another "9" in that string, Hoss, specifically 0.9999375, it is the same in all Wyoming zones.
That is one part in 16,000 less than 1, easy to remember that way.
GB
Posted : April 14, 2018 7:32 pm
I am a fan of low distortion projections.?ÿ Oregon has something like 25 defined zones and I routinely work in the "Portland Zone". The csf's are always much better than 1:100,000. It's not a problem.
Posted : April 15, 2018 7:58 am
Thank you Shawn. I would like to repeat one part of that.
Many (if not most) users of SPC projections have been misled. They believe that NAD83 to ground distortions never exceed 1:10,000. The main reason for this misunderstanding is the poor way distortions have been explained and understood.
The 1:10,000 number relates to the distortion between geographic and SPC Grid. Getting from grid to ground introduces additional mutilations that can exceed 1:4,000 or more.
We all engage in our favorite form of mathematical violence to offset these distortions. Hopefully the 2022 push will get more of us 'in the loop' on how to deal with it where we work...
Posted : April 15, 2018 9:07 am
Oops, missed a 9
Posted : April 15, 2018 9:26 am
aliquot
(@aliquot)
There is no reason to continue using state plane coordinates. Today's software can easily handle the real curved surface of the earth. We don't need these approximations that were developed when calculations had to he done by hand anymore.?ÿ?ÿ
Posted : April 15, 2018 9:27 am
john-putnam
(@john-putnam)
Oregon is up to 39 LDPs plus the two original state plane zones and the GIS lambert system covering the whole state.?ÿ Another nice thing is that we were able to remove the definitions from state statutes and place them under administrative rules.?ÿ This means we will not have to fight for legislative time to get the system changed.
Posted : April 15, 2018 9:34 am
The major reason I use state plane today?ÿis that so many computer programs will talk to it nicely. Yes an LDP will work for me, I've used them for a couple of decades now, but that data doesn't work well for so many other users.
I wouldn't mind a state plane zone that tried to mimic the actual land like an LDP does. That would mean adjusting the scale factor to account for elevations over the zone in question, maybe it isn't possible, but in the areas I work in there would be a number that gets you pretty close. Ignore the mountains, not much work there anyway, so now you have a 3000' range that almost all work is done in, adjust the scale to reflect that number.
Why make the numbers work at 0' on the ellipsoid when the lowest elevation is around 4000' After all it's?ÿonly numbers and there will be many sites where state plane will be within 10s of ppm. The best you can hope for in the existing State Plane?ÿis about 200 ppm and it goes up from there.
Posted : April 15, 2018 10:37 am
shawn-billings
(@shawn-billings)
Posted by: R.J. Schneider
~the field crew~
The reason, as I understand it, is so that the new datum will at a particular epoch be identical to ITRFxx. Currently, in 3D, there is about a 2 meter shift between NAD83 and ITRF08. This is largely unnoticed when using differential GNSS positioning, but gets to be more problematic with correction services. WAAS for example is based on ITRF. In its early days the difference was within the noise of the position accuracy, but as improvements have been made, users of the WAAS should account for the transformation to get the most out of the correction.
I am sure that if the SPCS zones remain the same (not replaced by LDP) that the grid origin will be assigned a new value just as was done between SPCS27 and SPCS83.
Posted : April 15, 2018 4:11 pm
shawn-billings
(@shawn-billings)
Posted by: JaRo
I want two things.
Both are technically possible, James, but would add a significant additional effort to the design of the LDP (at least regarding Grid North).?ÿ I've heard this request before and the reason given was so that coordinates from SPCS83 could be translated without the need for rotation. Is this your reasoning as well?
What many of the State-wide LDP designers are doing is giving a grid origin (i.e. False N, False E) value that identifies the particular zone the coordinate belongs to. So if you have 20 zones for a State, the Northing of Zone 1 would be in the 1,000,000's, and the Northing of Zone 13 would be in the 13,000,000's.
Posted : April 15, 2018 4:16 pm
shawn-billings
(@shawn-billings)
Posted by: aliquot
I'm all in favor of that transition, but the fact is that most of our software does NOT work well with geodetic coordinates. I'm unfamiliar with any CAD software that works this way (although I would be happen to be proved wrong!). I work for Javad GNSS as well as having my own survey practice. Our software is geodetic at the core, displaying grid coordinate values and inverses at the user's pleasure. I do believe this will eventually makes its way into our drafting and design software, but not any time soon.
Posted : April 15, 2018 4:19 pm
shawn-billings
(@shawn-billings)
When the new SPCS2022 definitions are published, software providers will need to add those zone definitions to their software. If those new zone definitions are LDPs then the software providers will simply be adding smaller LDP zones instead of larger SPCS style zones. Both types will use the same projection types, so no extra overhead there. They should play nicely with the software regardless.
The SPCS2022 default designs, which will use the current zones used by SPCS83, will be scaled to the topographic surface instead of the ellipsoid, so there will already be some improvement regarding linear distortion even using the large area zone definitions. LDP designs will be even better regarding linear distortion.?ÿ
Regarding weighting zone scale factors in mountainous areas, the scale factors would (should) be weighted to provide lower linear distortion in populated areas. This means that rather than a simple average elevation being used, the average will be weighted by population.
Posted : April 15, 2018 4:28 pm
I haven't seen the latest webinar (4/12?) yet, but to be honest, I don't really have strong feelings one way or another.
One thing is for SURE, no matter what the NGS decides to do about State Plane Coordinates, the same folks who can't seem to get their heads around the current system, won't be able to deal with the NEW system either. In fact, it might confuse them even further (assuming the proposed "topographic" changes come to pass).
As always, those who can, WILL, and those who can't, WON'T.
Posted : April 15, 2018 6:01 pm
The major reason I use state plane today?ÿis that so many computer programs will talk to it nicely....
When the new SPCS2022 definitions are published, software providers will need to add those zone definitions to their software. ....
That's how it is with Oregon's LDP.?ÿ StarNet comes loaded with them. Special files are available for C3d and SurveyPro so that it's a one time setup. Seamless.?ÿ
Posted : April 15, 2018 8:13 pm
They wouldn't have had to do anything at all except change the name.?ÿ They could have just told us to plug 2022 lat-lon into the old NAD83 formulas and call that the new state plane system.?ÿ With proper metadata that would work, but people would probably confuse things if the false N and E didn't change..
So the need for a new system is an opportunity to reduce the need to monkey with the lengths (and too often coordinates) in many applications.
Iowa has a 14-zone LDP regional coordinate system.?ÿ?ÿ It would seem to make sense to have a whole-state SPC for GIS work and re-use the existing zones with the needed changes for careful work.
Posted : April 15, 2018 10:14 pm
Page 1 / 3
