County road moved. Got improved, lots of base, and paved.
Its about 750' of road frontage.
Road is property line. C/L.
It moved up to 9'. Mostly about 6'. One direction.
Rd runs E-W generally. Both deeds call for rd c/l.?ÿ
Surveyed some 20 yrs ago.
We can define the old location within a foot.
Does the property line move with the road?
No.
If no one knew the road moved then maybe but it has to be unknown so the legal fiction that it has not moved can operate. But since you know the County moved the road then the boundary stays behind. Also the County is not a party to the boundary so their actions cannot affect it.
A dedicated right-of-way does not move. A prescriptive road easement may move with the new location, but the original property line does not.?ÿ ?ÿThe County has the right to move the road within a dedicated right-of-way. They do not have the right to widen or change the location of a prescriptive easement. All depends on the right-of-way deed or absence of a right-of-way deed.
The road would be tantamount to a disturbed monument..
I know whats the "legal thing to do".
But, I had a sentimental moment there.
Did the margins at the back of borrowpit move?
That is what defines the location of a road.
I say it does move, if I understand your situation, and I think I do.?ÿ Regardless of specific or general rules of construction.?ÿ Intent is always the underlying truth that controls.?ÿ I argue both sides intended to stick with the cl regardless of it moving around. It's an ambulatory boundary. Maybe the ROW lines move slower, maybe not at all, but that's a different issue.
So, are you saying that the private land owners on either side of the line intend to allow a third party (the county) to move their common boundary line wherever and whenever it desires?
Funny you posted this.?ÿ ?ÿJust had a call from a land owner.?ÿ ?ÿHe needs to know where his property line is.?ÿ ?ÿPeople are driving off of the road in to the ditch to miss the potholes and rocks.?ÿ ?ÿThe road is getting wider and apparently someone hit his fence.?ÿ ?ÿOf course he calls the county and they tell him that he can fence 12' from the center of the road, so he did (before it was hit).?ÿ ?ÿ He calls me for information.?ÿ ?ÿI pull up the plat and he is telling me this and I laugh and tell him the county is incorrect, unless it is a prescriptive easement.?ÿ ?ÿBut his property is in a subdivision and the roads have a dedicated width.?ÿ ?ÿHis is 60 foot.?ÿ ?ÿBut I also inform him that it isn't 30 foot from the center of the road.?ÿ ?ÿIt all depends on where it is built.?ÿ ?ÿI try to convince him to have it surveyed so I can definitely mark his property line but he has it figured out now and hangs up.?ÿ ?ÿThanks to the county, I might be getting some work unless the ROW moves with the road.?ÿ ??ÿ ??ÿ ??ÿ
roadbeds are sometimes marking the centerline of a road and sometimes not.
well, I suppose that means there'll be another Little Natester showing up in about 40 weeks....?ÿ ??ÿ
Nate,
I think you knew the answer already. I know there are some strange opinions about ROWs on here, but to claim the actions of a county bulldozer operater can effect the property line between two private parties is crazy talk.
Nate,
Alliquat,
Tis true, yes, tis true...
But, it also brings up the issue of surveys, I've seen, that obviously, poorly defined the road... They were trying to keep the numbers out of the road location. They only?ÿ approximately showed pi's, and those were adjusted to make the acreage about right.
Now I understand that old codger... With a grandfathered pls #.
