#481 is the calculated point, #1360 is the located point, 481 will be erased and discarded in both my GPS and AutoCAD files, I won't use it to calibrate to. The projection is an LDP with the central meridian a few miles to the west so I'm close to true north at this point which is a 1/4 corner. The stone was a bit over 4' from the calc.
I understand what you are doing, calibrating to calculated positions to find the?ÿother calc?ÿpoints. I prefer to calculate them on the projection ahead of time.
Posted : April 30, 2018 8:08 am
