Promark 2 - code 32
2 Users
stacy-carroll
(@stacy-carroll)
Does anyone remember how to initiate a "Code 32" on a Promark 2? I have one that is acting up and needs a little discipline. Somewhere I wrote down the procedure but can't find it...
Me. "What's the difference?"
Posted : August 31, 2011 10:07 am
From the PM2 FAQ:
Q. What do I do if my ProMark2 stops tracking or locks up after a firmware load?
A. Some hardware operation problems can be corrected by clearing the receiver memory with a “code 32”. With the ProMark2 turned off, hold down the NAV button and tap the PWR button. In a couple of seconds a small box displays on the screen with “00” inside it. At this point, release the NAV button. Use the direction pad to change the “00” to “32”, then press ENTER. DO NOT use any other key combinations, they may cause the ProMark2 to become unusable and void the warranty.
Executing the code 32 will cause the receiver to revert back to the default 4-character ID of "1234". Please note that each receiver ID must be unique among all receivers used together in a survey. Otherwise, raw data files will be given the same name, causing problems when the data is downloaded to the same location on the office computer for processing.
Posted : August 31, 2011 10:12 am
stacy-carroll
(@stacy-carroll)
Thanks Jim! I'll see if that corrects the problem...
Posted : August 31, 2011 10:19 am
