ok- what happens when someone (me) actually
11 Users
digs out the corners-
a- treat the east pins as closing corners on the R/W-
b- bend the R/W thru the pins
c- nothing- the found monuments will be as shown on the amended plat.
this is near and dear to my heart right now- just a few blocks away, we buzzed a pin- nice sharp location- and by the time we got to the true position it was about 0.8' away from the buzz -
Posted : September 11, 2013 8:15 am
Brass, Plastic, and Aluminium... all "magnetically detected"
Where can I get one of those?
Lazy, Ignorant, Button Pushers... :bad:
Oh, forgot "simi literate"
Posted : September 11, 2013 8:53 am
 jud
(@jud)
Magnetically Detected what? Don't know, don't use.
jud
Posted : September 11, 2013 8:56 am
(@perry-williams)
good to see you posting.!
good to see you posting. I was hoping you weren't the guy from Kalispell who got pushed over the cliff by his wife.
Posted : September 11, 2013 9:54 am
(@jered-mcgrath-pls)
So basically the prior individual found the BC and the two lot corners and then slapped the record plat on them, Heard a ring at the other intersection corners and then set the perimeter of lots based upon "spidey sense" and a "warm fuzzy feeling".
Not much regard for Boundary establishment principles and or retracing solid evidence of controlling lines.
Call them, show them your findings and give them an opportunity to correct the mistake. (Probably runs rampant on all of their surveys though if this is an indicator.)
Sounds like you already know the answer to your question.
Posted : September 11, 2013 9:59 am
(@joe-ferg)
That thing is wrong on sooooo many levels.
Posted : September 11, 2013 11:38 am
(@scotland)
When I first read this, I thought it was "magically detected..." I've personally had a few of those and dug down and never found the "magic". Missed it when I was digging the man size hole!
Posted : September 11, 2013 12:20 pm
Did you mean "semiliterate"? 😛
Posted : September 11, 2013 2:08 pm
(@dave-lindell)
I had a helper once who could dig huge holes and then finally spot it stuck in the side of the hole. And that was with the help of a metal detector!
Posted : September 11, 2013 2:27 pm
 jud
(@jud)
Used to be some instructions on how to tighten up the under ground location of a vertical pin. I still use it when I need to open a hole in a hard surface. The method uses the known spacing of the detectors along with the pin finder being parallel to the surface.
jud
Posted : September 11, 2013 6:35 pm
(@jack-chiles)
I did not think one could detect a brass or aluminum
cap with a magnetic field locator. Perhaps if it were affixed to an iron rod....;-)
Posted : September 12, 2013 4:52 am
(@asanchez)
Monuments hold so who cares what he has? Everybody gets a slightly different answer anyways?! Don't ever pay any attention to those perfect pristine numbers!!
Posted : September 12, 2013 8:56 pm
ok- help me out here.
Which monuments hold? the ones he didn't find or the ones he set based on the ones he didn't find? o.O
Posted : September 12, 2013 10:10 pm
