Nail Driving Prism Pole
22 Users
john-putnam
(@john-putnam)
Some time ago I remember seeing a prism pole attachment that would drive mag nails.?ÿ Does anyone recall this or am I losing it??ÿ I have an upcoming layout job that needs nails set every 50 feet for 1.5 miles and figured this might work well.?ÿ?ÿ
Posted : December 18, 2019 4:03 pm
john-putnam
(@john-putnam)
I found the old thread.?ÿ Looks like no one knew where to get one.
Posted : December 18, 2019 4:13 pm
Have you considered a framing nailer? Or a concrete nailer??ÿ
https://www.amazon.com/dp/B00005QVTB?creativeASIN=B00005QVTB&linkCode=w61&imprToken=rjBiEiEzdZXgppz.R5VC5A&slotNum=5&tag=tlbox33-20
Posted : December 18, 2019 4:24 pm
OSHA probably declared those former tools too dangerous for the jobsite.........
Posted : December 18, 2019 4:32 pm
rundatline
(@rundatline)
Ramset single shot for $75 if you shop around.
Posted : December 18, 2019 4:55 pm
Norman_Oklahoma
I'm thinking some 1/2" tubing with 1/2" rod inside, 4 feet (or so) long, would make a good slide hammer. Just need to devise some manner of holding the nail in place to get it started.?ÿ
Posted : December 18, 2019 5:29 pm
Posted by: @john-putnam
Years ago I did a job for the city's DPW cross-sectioning 3,000' of a downtown arterial (only 4 lanes at the time, but it was heavily used).?ÿ I finished the topo and delivered it to the city, but the PM came back to me and said that he assumed that our proposal included setting nails & shiners on centerline at every 50' station.?ÿ I no longer remember why we didn't balk at that, but we didn't, and all I can say is that I'm lucky to have lived through it.
Posted : December 18, 2019 9:11 pm
k-huerth
(@k-huerth)
What about something like this?
https://www.amazon.com/Metabo-HPT-W6VB3SD2-SuperDrive-Fastening/dp/B07SR5MD8J/
Posted : December 18, 2019 11:04 pm
mvanhank222
(@mvanhank222)
If we have to set a lot of nails in asphalt I typically use 1-1/2ƒ? to 2-1/2ƒ? bright finish fluted masonry nails they drive really well and donƒ??t tend to chip the pavement like pks. If itƒ??s concrete I prefer to use tapcons but you need a cordless hammer drill for the pilot holes.
Posted : December 19, 2019 5:58 am
tim-v-pls
(@tim-v-pls)
I've used a Remington Power Pro Semi Automatic Model 496 for similar application.
Posted : December 19, 2019 12:20 pm
john-putnam
(@john-putnam)
@flga-pls-2-2
I have, somewhere, an powder charged concrete nailer.  I was looking for something that shot the point in when the rod had it correct spot without having to mark the point then nail it.
Posted : December 19, 2019 12:21 pm
dmyhill
(@dmyhill)
My automatic power hammer is a dude in his 20's with big biceps. I point, he installs nails. Works great/
Posted : December 19, 2019 12:46 pm
adamw
(@adamw)
This isn't exactly what you're looking for, but would be half of the solution:
https://www.surveying.com/en/center-punch-point.html
you can at least mark the point accurately without moving the pole
Posted : December 19, 2019 2:37 pm
@jim-frame
yowza
Posted : December 19, 2019 3:33 pm
john-putnam
(@john-putnam)
@adamw
I might have to check that out.  Not that it matters on this job but I wonder about the rod height stability.
Posted : December 20, 2019 9:55 am
jones
(@jones)
@john-putnam
We have one, it works great for creating a dimple in asphalt and concrete. I would not use it if I was worried about tight elevations, there is a significant amount of give in the tip.
Posted : December 20, 2019 10:21 am
dmyhill
(@dmyhill)
@adamw
I hold the rod on the pavement, shoot it with paint, and the resulting shadow lets me put a nail at pretty much the exact tip of the rod. I am not sure how tight you have to be if you are staking centerline like this. I would think a hundredth here or there would be just fine. And then, I am serious about having the second follow behind. I have "set" those paint shadows and had the second follow behind with nails and painting the info.
Posted : December 20, 2019 10:49 am
MarkSilver
(@mark-silver)
I found this tip at InterGEO in 2016:
(this is a cut-away view)?ÿWhen you push the rod down firmly it puts a dot at the rod center.?ÿ
Here is the data sheet on them:
They are 'only' $145Euro , but I was impressed that they were REALLY well made.?ÿ
Here is a link to online: https://goecke.de/Products/EDM-Accessories/GPS-antenna-tripod--tripod-and-bipod-for-prism-and-antenna-polesSECO--GS-SURVEY-plus-and-LEICA--levels/Accessories-for-Antenna-Poles/product-907.html store where you can pick them up.
Posted : December 20, 2019 2:09 pm
nomee
(@nomee)
@mark-silver
GOOD MORNING
THATS VERY NICE I HAVE A QUESTION I CAN USE ANY MARKER WITH TAHT OR I HAVE TO BUY THE SAME BRAND MARKERS.
Posted : December 23, 2019 8:09 am
MarkSilver
(@mark-silver)
@nomee
I suspect that you need the GOECKE markers, but it won't cost much to add a 5 year supply in the same box as the springgy-tool thing. The dots that it makes are pretty nice actually, they have a dome shape and take a moment to 'cure' but are really nicely formed.
I believe I may have asked about selling these in the USA and been told that they had representation already. So you might be able to purchase here; although my German is not 100% perfect so there might have been a LIT event (Lost-In-Translation).
Posted : December 23, 2019 9:59 am
