Leica Sets Of Angles/CS20/Captivate
bmwalshy
(@bmwalshy)
Hello All,
Does anyone have any pdf links or a video tutorial n using Leica Sets of Angles?
It does not seem very user friendly, and Iam not working with anyone whom uses it.
Any advice would be appreciated.
Thanks in advance
Posted : May 17, 2018 2:34 pm
john-putnam
(@john-putnam)
The routine is quite simple to use.?ÿ When you first enter the its asks if you want to create a new point group.?ÿ You can use the default or name it yourself but the group name must be unique.?ÿ Next it asks how you would like to enter the points into the group, measure points is the standard answer.?ÿ I will then ask for the measurement sequence i.e. FBB'F' or what ever flavor you desire.?ÿ Then you point at the first target you want to shot (usually the backsight); enter the HR, prism type and measurement type; shot the point; and repeat for all the desired forsights.?ÿ Once you have turned the direct to each forsight you enter the done key.?ÿ The program will then finish the first set and ask how many more you would like to wrap.?ÿ The is a detailed description of the routines operation in the 1000 page technical reference available on Leica's myworld.
Posted : May 20, 2018 9:58 am
wfwenzel
(@wfwenzel)
"When you first enter the its asks if you want to create a new point group"
I'm afraid you lost me there.............
Posted : May 23, 2018 12:40 pm
