Laser Scanner applications
Cliff Wilkie
(@cliff-wilkie)
Am trying to get a handle on how many surveyors are actually using stand-alone laser scanners and what kind of jobs/clients they are using them for. I'm interested in either the combination total station/scanner as well as the more expensive units that only scan. All manufacturers are touting them as the wave of the future and a tool that will replace conventional topo methods. I am not sure that many surveyors are actually using them very much so would like to get some response from surveyors who are actually using them in their business practices. What are you using them for? How much use? For what type of clients? How difficult is it to work laser scanning into your existing work practices?
Posted : March 5, 2015 3:43 pm
d7330
(@d7330drdrbcom-2)
Here's a few discussions regarding this topic recently: (I just used the search function in the upper right corner of the site.)
https://surveyorconnect.com/index.php?mode=thread&id=298263
https://surveyorconnect.com/index.php?mode=thread&id=302956#p302987
https://surveyorconnect.com/index.php?mode=thread&id=283503
Posted : March 5, 2015 5:13 pm
makerofmaps
(@makerofmaps)
We use them to scan substations, inside of plants, small site topos if the terrain is willing. One of the new process we will use them is to verify distributors have fixed clearence violations near our lines. Targetless registration makes life so much easier now. On the substaion side scanning makes our life so much safer.
Posted : March 6, 2015 7:44 am
Matt Lewandowski
(@matt-lewandowski)
What size are the drawing files for a scan? I assume that the file size would remain roughly consistent per individual scan (correct me if I am wrong). And is there a rule of thumb on the number of scans per acre?...assuming line of site is good. -- Thanx
Posted : March 6, 2015 8:00 am
Richard Davidson
(@richard-davidson)
We use them on mainly Engineering Surveys. On things that are expensive when they are not running and the owner wants to decrease downtime. When design and construction can be made in a point cloud, things fit together better.
Spar Laser Scanning Bootcamp 2010
Posted : March 7, 2015 10:26 am
Zoidberg
(@zoidberg)
We have the Leica C10. We have one crew who uses it several times per week, preferring it if the situation fits. It's used for volumes (material piles, quantities), we did a pre and post scan on a rock face to calculate volume of rock removed, corridor surveys on highways and urban/village settings (face of building to face of building), we have scanned the inside of large concrete culverts, we've used it for topo surveys utilizing virtual surveyor and cutting cross sections along an alignment, we scan bridge piers and abuttments to check deformation (monitoring)... There are so many uses for it, it's just a matter of embracing it. It's a tool. If you have it in the truck you'll use it, if you don't have it in the truck you'll come up with reasons why you don't need it.
Edit: We've also used them for bridge work in the design phase. Scan where the abuttments will go and our engineers are starting to design right on the cloud without having to do data extraction or terrain modeling.
Posted : March 9, 2015 6:44 am
