Laser for Inverts
14 Users
CT
 CT
(@ct)
Hello-can anyone recommend a decent laser for measuring hard to reach pipe inverts? Thanks for any replies.
Posted : August 22, 2021 7:18 am
Learner
(@learner)
I have a little Bosch handheld--GLM42 that I love.?ÿ I would use it for manhole depths.?ÿ Not sure it would be effective with any significant flow in invert...?ÿ I gave a hundred bucks for it a couple years ago, and it has paid for itself many times over.
Posted : August 22, 2021 8:06 am
CT
 CT
(@ct)
@learner -thanks! That particular unit is out of stock, but I would imagine any in that class would do the job.
Posted : August 22, 2021 11:13 am
@ct?ÿ
Look for a model that does "indirect measurement". That is Bosch speak for correcting the slope distance to vertical (or horizontal) by applying a vertical angle.
I have the GLM42 and it is, hands down, the best method of doing measure downs I've ever hit on. And I've tried them all in 30 years. It will penetrate and couple of inches of flow.?ÿ ?ÿ
Posted : August 22, 2021 12:23 pm
martin_au
(@martin_au)
I work for a water utility, so this is pretty well my day to day. Disto s910, combined with a rod that holds the disto at the MH centre. I will post a listing/design for the rod brackets today.
Posted : August 22, 2021 3:14 pm
CT
 CT
(@ct)
@mark-mayer Great! Thanks Mark!
Posted : August 22, 2021 4:07 pm
CT
 CT
(@ct)
@martin_au thanks Martin!
Posted : August 22, 2021 4:08 pm
Bruce Small
(@bruce-small)
Be aware it is my experience that the liquids in the manhole channel will reflect the laser and give an incorrect reading, or more often an error message.
Posted : August 22, 2021 8:17 pm
amfromnome
(@amfromnome)
@martin_au A fellow s910 enthusiast, I see. Good little unit, worth every penny for so many uses.
Posted : August 22, 2021 11:28 pm
martin_au
(@martin_au)
@ct Found a picture of the S910 setup. Basically a rod with a couple of supports each side, and a bracket in the middle to hold the S910. This puts the disto in the centre of the MH.
Posted : August 25, 2021 2:18 am
Norman_Oklahoma
The Disto is $1000 or more. The Bosch is around $100. Just sayin'.?ÿ
Posted : August 25, 2021 8:39 am
martin_au
(@martin_au)
@norman-oklahoma and the Bosch canƒ??t do what the Disto can.
Posted : August 25, 2021 3:11 pm
Norman_Oklahoma
@martin_au?ÿ
I measures the vertical to a pipe invert very nicely.?ÿ For $1000, I expect the Disto to serve me coffee, piping hot. Damn fine coffee.?ÿ
Posted : August 25, 2021 4:06 pm
Posted by: @norman-oklahoma
While the manhole is still open?
Posted : August 25, 2021 4:12 pm
martin_au
(@martin_au)
Itƒ??s all fun and game until someone asks for pipe/mh chamber diameters. 😀
Posted : August 26, 2021 4:43 pm
CT
 CT
(@ct)
I tried several of the units mentioned, but ended up buying the Leica Disto X4 ($376 on Amazon). It measures the angle and slope and reports the calculated vertical. The Disto X3 does the same for $100 less, but the target viewer?ÿ on the X4 is well worth the extra money.
Posted : September 14, 2021 5:40 am
@ct thanks. ?ÿI see in ƒ??officialƒ? descriptions that it somehow easily obtains horizontal distances. ?ÿHow do we get vertical distances in a manhole? ?ÿDoes it have some sort of internal plumb line? ?ÿOr do we have to just roughly guesstimate a vertical plumb line and then record the angle to an invert that is recessed or offset inside a structure? ?ÿI hope these are reasonable questions that make some sense. ?ÿI think I have bought several devices from beer leg recommendations like this on Amazon (I have a Bosch too, but I think it only measures direct slope distances) then they go in a corner somewhere and get forgotten and never used. ?ÿI do invert measurements so infrequently these days I forget about the tools (toys) and grab the poop stick out of extremely old habits when the time comes for one of those jobs.
Posted : September 14, 2021 8:01 am
CT
 CT
(@ct)
@brad-ott Brad, the X3 & X4 measure the slope distance and angle to the shot, calculates the vertical (side b) and displays the lengths a, b & c and included angle. Works great for manholes & storm inlets where the pipe is offset so as to prevent a direct measurement. I wouldn't trust it for a sewer line with moderate to heavy flow. Although if you know the pipe size you could take the shot to the top of the pipe and add the size to the reported side b measurement for the invert.
Posted : September 14, 2021 8:30 am
Posted by: @ct
How does it know the angle to vertical??ÿ ?ÿDoes it have some sort of internal plumb line??ÿ Or do you "tell" it where vertical is, by roughly setting zero on an eyeball plumb line? or, ,...?
Posted : September 14, 2021 8:40 am
CT
 CT
(@ct)
@brad-ott the specs can be found https://shop.leica-geosystems.com/disto-job-site-measuring-us#x4
Posted : September 14, 2021 8:54 am
