HP48 with TDS (again)
7 Users
(@geezer)
Guys n Gals,
I have an HP-48 with a "COGO GX/SX" in it. (There is no RAM card. Never has been)
I used it only a month or so ago, and all was fine with the cogo routines.
I tried yesterday, and when I turned it on, it was at the "Home" screen for the 48, not the TDS screen. I typed in "alpha alpha TDS48" and it does nothing, but display what I typed.
I went through the normal procedure of erasing the memory and re-installing the cogo card, with the exception that I only have one card (no RAM card), and still get the same results. (The normal procedure I have instructs to put the COCO card in slot 1, and then move to slot two). I have tried it both ways, to no avail.
I have searched the forum (which is where I got the routine mentioned above.
I appreciate your indulgence and assistance.
Thanx,
Geezer:-)
Posted : October 11, 2014 4:26 am
(@scsurvey)
Does this mean you did a cold boot on the 48?
If not I would recomend that. If my memory is correct, and I will say it is very rusty on the 48 as mine broke (read was broken for me) about 5 years ago:pissed: to do this you hold the upper right, upper left, and the power button down at the same time. If it is not this combo it is a combo of three of the four corner buttons.
The other common problem I remember was I often forgot to turn "user mode" on.
Good luck.
Woody
Posted : October 11, 2014 4:52 am
(@james-johnston)
If the first reset does not work, there is also a way to do one by holding a needle in a small hole in the back of the calculator for number of seconds, I forgot how many exactly.
Posted : October 11, 2014 4:55 am
(@scsurvey)
James I forgot about that one, I think the hole is under the rubber foot pads on some of the earlier 48's.
Posted : October 11, 2014 5:05 am
(@jimmy-cleveland)
Try "TDSCOGO" I think that is what my cogo card requires.
Posted : October 11, 2014 5:20 am
(@roadhand)
:good:
Posted : October 11, 2014 6:49 am
(@tom-wilson)
"alpha alpha TDS48" alpha enter
You must turn alpha off to get the instruction to execute, alpha, alpha locks it on.
T.W.
Posted : October 11, 2014 7:38 am
(@jimmy-cleveland)
I just tried my TDS Cogo Card, and my card is TDSCOGO. I think the TDS48 is for the data collection card.
Posted : October 11, 2014 7:44 am
 vern
(@vern)
alpha alpha "fc48" enter is one way in on mine. You can also choose the library. If I remember right it's purple "library" then look for it.
Posted : October 11, 2014 7:53 am
 vern
(@vern)
I just pulled mine out and the answer is;
green 2 ("library"), choose main (C), then "nxt" until you find the TDS program. It could be TDS TDS48 FC48 TDScogo etc.. It changed with each generation and software package.
Posted : October 11, 2014 9:15 am
(@geezer)
"TDSCOGO" was it.
thanx again to all.
Geezer;-)
Posted : October 12, 2014 10:08 pm
