On re-reading the specs the S6 value was for 100m and the S7 value is for 50m so there is no improvement on the beam size from the S6. You were correct Rover83 Leica has the edge on this. Hopefully Trimble will improve this with their next robot.
I think things might have changed a bit in the 9 years since that video was made. Lol
Should it?
Doesn't really matter as long as the facade is flat and not warped. I tend to try for at least a half dozen points and cover as much as I can see from the setup. Since I don't care about height of the shots I can knock it out a lot faster?ÿ
I usually do building faces right after I set up, or right before I break down the setup. Unless I'm running the SX10 I can do building faces faster while standing at the instrument.
Same here, unless we get to it before the walls are up it's easier to shoot reflectorless. I was always walking up to the corner and checking where the beam hit since it didn't seem to land where sighted (at least on the Sokkia ix - the loaner topcon gt seems to be pretty good). If you saw the quality of the foundation corners we are usually shooting you can see why we're not extremely fussy about them. If I shot it at several different heights along the corner I'd have several different shots. A building corner check is never the best.?ÿ
I could start shooting multiple shots but I'd have to intersect them myself on the tablet. The office would likely be annoyed with the extra work I just created them.?ÿ
It would be a different story if I was doing an srpr or topo on an existing building that's already built. Usually I'm tieing in a foundation on a "dwelling under construction" with chunks missing from the foundation, bends in the walls etc. Stuff that makes the framers very grumpy.?ÿ
I can only dream of using an sx10. Scanning is just a distant goal in my bosses mind.?ÿ
I??ve a question about Trimble S instruments:
where can I find the EDM constants for PPM calculation? Commonly known as ??first velocities??.
I??ve found several sources for 1st velocity for EDMs, but circa 1995. Nothing newer.?ÿ
Once you are connected to an instrument, select the menu button, then go to Instrument -> Adjust.
It will take you through all the various calibration routines like compensator, collimation, trunnion axis, etc.
The last item should be "EDM constant". I think that's what you are looking for.
(This is using Access, I am not sure how to get to that setting using third-party field software)
yes, I??m looking for those values.
The formula is:
PPM= C - (Dp/K?ø)
p is pressure ?ÿ
The EDM specific constants are: C and D.?ÿ
This doc list many EDM models. But it??s old and doesn??t list Trimble.?ÿ
https://link.springer.com/content/pdf/bbm%3A978-3-642-80233-1%2F1.pdf
I usually do several per building face. Definitely 1 close to each end.
