I was wondering if anyone has knowledge or experience using encrypted thumb drives on a TSC3? I am able to see and use unencrypted thumb drives no problem. I am trying to get the information from the data collector to the computer back in the office and for the information be encrypted between both points. The TSC3 is able to encrypt information that goes into the a thumb drive but only that exact TSC3 is able to read it, so that is not something I can use. Thanks for your help!
It probably won't work. The O/S on the TSC3 is pretty old and not supported by Microsoft any longer. If you are using a hotspot to connect it to the internet, you have to have the encryption turned off in the hotspot. If you want to use Gmail, you have to use a third party email client because the security that Gmail uses is not supported by the O/S.
If you have that much of a need for encryption, just download it directly to your computer.
Thank you for your reply! I've been searching and came up with nothing. It really seems like there is no way.
