Yesterday the FC2500 would connect to the base and rover but would not start base. Tried everything, no luck. I connected with the Topcon Robotic by bluetooth OK. It connects but no data transmission seems to take place. Help!!!! All lights are normal on the face of the base and rover.
Hiper Lite Plus Post 1
Hiper lite Post 2
Hiper Lite Post 3
I assume you tried the MINTER reset and reset the FC2500.
EDIT: It takes a 4-8 minutes to download all the satellite data after you do this, so be patient.
Steve
I agree, reset both GPS units and the data collector. We had a pair of Hipers a few years ago and would have to reset them every so often.
David Livingstone, post: 365842, member: 431 wrote: I agree, reset both GPS units and the data collector. We had a pair of Hipers a few years ago and would have to reset them every so often.
I will re-set the minter now. I did re-set all three in the field but I will go PCCDU and see if the settings are correct. Thanks
