Helmerts mathematics
summerprophet
(@summerprophet)
Hi all,?ÿ
I am making an excel spreadsheet to do a helmert's transformation. This basically mimics the old Helmerts program for the HP48.?ÿ
What I am lacking is the "Set scale to 1" function, which would be valuable.?ÿ Unfortunately, my knowledge of the mathematics is lacking, and I uncertain how this step is done. Most of the hemerts research i have uncovered involves graphing it in excel and is not specific to surveying.
If anyone is willing to give it a look, I can provide the spreadsheet and the sample data.?ÿ
Posted : May 8, 2023 8:29 am
OleManRiver
(@olemanriver)
Member Debater
How many parameters are you looking to perform 3 or 7 etc.
Posted : May 8, 2023 4:00 pm
jacob-wall
(@jacob-wall)
There are a few different approaches to solving these in general. I have implemented at least 3 different versions of the 2d similarity transformations over the past ~15 years so I might be able to help. Please post or send the Excel file and I will have a look. It's typically quite straight-forward to force the scale to 1.
Posted : May 8, 2023 7:00 pm
summerprophet
(@summerprophet)
@olemanriver
Just a 2d transformation.
Posted : May 9, 2023 7:56 am
OleManRiver
(@olemanriver)
Member Debater
@summerprophet gotcha.
Posted : May 9, 2023 8:34 am
summerprophet
(@summerprophet)
@jacob-wall
Private message sent.
Posted : May 9, 2023 8:51 am
mathteacher
(@mathteacher)
Apparently, the answer to the question of finding Helmert 2d coefficients with a scale factor of 1 was answered by private message. Maybe it’s arcane, but exploring the process yields some valuable insights.
First, the short answer to the question. The two equations that rotate and scale one map projection into another via Helmert 2d transformation are:
where:  N’ and E’ are the transformed coordinates,
              N0 and E0 are constants determined by analysis,
              s is the scale factor determined by analysis.
      and  is the rotation angle determined by analysis.
The typical analysis method is a multivariate linear regression.
Just a little independent algebra yields:
Thus, we calculate the scale factor s and divide the coefficients of N and E, but not the constants, in both of the above equations by that value of s. The resulting equations have a scale factor equal to 1.
Here are the coordinates of 5 points on an LDP near Pinehurst, NC that are also NGS survey marks. They are identified by their respective PIDs. The LDP is a Lambert conformal projection tangent to the topographical surface at 35° 10’ North and 79° 29’ West, origin at N = 25,000, E = 100,000, and k0 = 1.00001579.
LDP
NC SPCS
Point
Northing
Easting
Northing
Easting
DH9398
24,269.961
99,569.154
156,522.732
566,657.950
DH9405
26,643.312
99,991.063
158,893.737
567,090.950
DH9410
27,403.534
102,077.674
159,644.035
569,180.813
DH9408
26,128.143
102,380.720
158,367.415
569,477.819
DH9397
24,066.459
102,671.253
156,304.681
569,758.619
The task is to rotate and translate the LDP into State Plane using a 2d Helmert transformation. Least squares linear regression produces the following equations:
NorthingSPCS =  132,724.475 + 0.99984696*NorthingLDP  −  0.00470014*EastingLDP
Eastingspcs = 466,989.975 + 0.99984695*EastingLDP + 0.00469968*NorthingLDP
The coefficients are products of a scale factor and a trig function. The two cosine coefficients should be equal and the two sine coefficients should be equal, and they’re very close. But we’re dealing with squaring numbers with 9 significant digits in Excel. The correlation coefficient is not exactly one in either case, so there’s a millimeter difference between some of the actual SPCS coordinates and their corresponding transformation values.
From the equation for Northingspcs:
Our coefficients with s = 1 become:
0.99984696/0.99985800 = 0.99998896 and 0.00470014/0.99985800 = 0.00470081.
These are the cosine and sine, respectively, of the rotation angle. For a quick check of the process, we can compare the rotation angle to the convergence angle on the data sheet for DH9405. Why should these values be so nearly equal?
The LDP coordinates are ground coordinates. Using the coefficients that include s < 1 produces state plane coordinates. The scale factor scales the coordinates from ground to grid. Comparing transformed coordinates to data sheet state plane coordinates checks this claim.
Using the coefficients with s = 1 produces ground coordinates. The scale factor leaves the LDP scaling intact. This can be checked by comparing distances computed from LDP coordinates to corresponding distances computed from coordinates transformed with s = 1.
Here are the transformations:
Transformed to SPCS, s<1
Transformed to Ground, s=1
Northing
Easting
Northing
Easting
156,522.732
566,657.951
156526.1124
566672.118
158,893.737
567,090.949
158897.4539
567105.179
159,644.035
569,180.814
159647.8587
569195.341
158,367.415
569,477.819
158371.0572
569492.388
156,304.681
569,758.618
156308.0303
569773.227
This is a perfect example in that both sets of coordinates are geodetically determined on the same ellipsoid and by the same map projection. It lets us understand the process, but real-world transformations are likely to be much messier and have poorer correlations. Each has to stand on its own merit.
Here are three useful references:
Helmert 2D - MDT Surveying Manual (aplitop.com)
Transformation methods | Lantmäteriet (lantmateriet.se)
Helmert transform — PROJ 9.2.0 documentation
Posted : May 16, 2023 9:13 am
