Dzign HP35S/ HP 33s Cogo Programming Book
10 Users
ariddle
(@ariddle)
Does anyone know if the HP33s Dzign survey cogo programming book work for the HP35s? If not does anyone have a copy that they wouldn't mind getting rid of?
Posted : May 25, 2018 9:21 am
protracted
(@protracted)
Dzign sells survey programming books for both HP 33s and 35s.?ÿ My guess is that they are not interchangeable and only work on the specified calculator.?ÿ I've been using Dzign software on a 35s.?ÿ I wasn't quite sure which of the available softwares would be best but decided to try Dzign and it seems fine.?ÿ
Best regards, Eli
Posted : May 25, 2018 10:36 pm
summerprophet
(@summerprophet)
The HP33 and the HP35s use slightly different programming languages. So the programs are not interchangeable.
Posted : May 27, 2018 8:41 pm
just-a-surveyor
(@just-a-surveyor)
That just reminded me that about 15 years ago a Irish fella from the old message board bought half a dozen program books for my HP42.
Those programs worked good but if the batteries died and you didn't have a fresh set it was many hours of keying in all the codes again.
Posted : May 28, 2018 5:31 am
edward-reading
(@edward-reading)
Posted by: Just A. Surveyor
Ugh, don't remind me.
Posted : May 28, 2018 8:22 am
jrhernan
(@jrhernan)
Steven, hi i like the info on your post,
any chance you have any HP42s survey stuff you would sell ....i still have my 42s in working condition, ever since it was new in about 1994 when i was in Cortex CO with the BOR.
thanks in advance for any reply !!
joe
Posted : May 29, 2018 6:14 am
travis-caldwell
(@travis-caldwell)
I have programs for the 35s I could send you if you're interested.
Also the batteries on a 35s last about a year and when they die all the programs go too.
The painful memory is still fresh as it just happened last week.
Let me know,
-Travis
Posted : May 29, 2018 6:24 am
Randy Rain
(@randy-rain)
Replace the batteries before they go dead, and replace them 1 at a time, never removing both batteries at the same time and you will not loose your programing. I replace mine every 6 months and cycle the used batteries into rotation for guitar tuner batteries, if those go dead no biggie.
Posted : May 29, 2018 6:47 am
just-a-surveyor
(@just-a-surveyor)
Posted by: jrhernan
joe
Joe; Nope, all gone, sold them to some fella in Ireland years ago and never missed them.?ÿ
Randy; That does not work. Once the circuit is broken by the removal of a single battery all power is lost. I seem to recall that the HP42 had a residual charge that allowed for removal and replacement of batteries but they had to be done in about 15 seconds otherwise...ƒ??.kapupt.
Now I suppose you could build a bridge and use some alligator clips and a spare battery to hook to the terminals and maintain a charge while you change batteries but I never did.
Posted : May 29, 2018 7:07 am
Randy Rain
(@randy-rain)
Sitting here looking at my HP 35s with one battery removed and the screen even still has digits on it. Just removed both batteries (1 at a time) and all of my programs are still there so I suggest that you give it a try. So long as there is a decent amount of charge in the single battery no loss of programing. Just don't let them get too close to dead. I've had this 35 for about 4 years, I'm on my 8th set of batteries and only programed it once.
RRain
Posted : May 29, 2018 9:30 am
just-a-surveyor
(@just-a-surveyor)
Randy, I have no experience with the HP-35, I was referring to the HP-42. The 42 was a P.O.S. and I spent a lot of hours on many nights and weekends reinputting the programs.
Posted : May 29, 2018 9:36 am
ariddle
(@ariddle)
Travis- I have a coworker that is interested if you don't mind passing it on.?ÿ
Posted : May 30, 2018 8:54 am
jrhernan
(@jrhernan)
great i can look them over during the summer work slow-down,
thanks !! i would greatly appreciate any info you could send me or sell to me on the HP35, i have to start looking at that calculator if the NCEE people don't allow just any calculator....
joe
[email protected]
Posted : May 30, 2018 12:23 pm
protracted
(@protracted)
Over the years, I found a few other calculator program sources as well.?ÿ I've been surprised that these weren't more obvious.
http://www.wollindina.com/index.php/hp-calculators/hp-35s-calculator
http://www.hp33ssurveyor.com/hp35s/
Best regards, Eli
Posted : June 1, 2018 12:16 am
tfdoubleyou
(@tfdoubleyou)
Seems like a relevant place to post a program I wrote about a year ago. It will convert Feet, Meters, Varas, Rods, Chains, Links, into all of those same units. In operation, it will prompt you for a value to convert from, F, V, R, C, L, in that order. If you leave it blank and hit R/S it will cycle to the next unit. When you enter a value, it will start giving you the conversions, output in the same order as the input. It will give you back the same unit you provided for a check. It works by converting whatever you enter into feet, and then from feet into the different units, so I suppose there is some accuracy loss, but it's worked for me for testing purposes.
X001?ÿ?ÿ?ÿ LBL X?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ ?ÿ?ÿ ?ÿCan be whatever letter you want
X002?ÿ?ÿ?ÿ CLRVARS?ÿ?ÿ?ÿ?ÿ ?ÿ?ÿ ?ÿBlue Key -> Clear - > 2
X003?ÿ?ÿ?ÿ CF 10?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ ?ÿ ?ÿYellow Key - > Up Arrow -> 2 -> <decimal key> 0
X004?ÿ?ÿ?ÿ INPUT F
X005?ÿ?ÿ?ÿ X/= 0??ÿ?ÿ?ÿ?ÿ?ÿ ?ÿ?ÿ ?ÿBlue Key -> Mode -> 1
X006?ÿ?ÿ?ÿ GTO X030?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ Letter should match LBL of Program
X007?ÿ?ÿ?ÿ INPUT M
X008?ÿ?ÿ?ÿ (Mx39.37)?ú12?ÿ?ÿ?ÿ?ÿ EQN, Then RCL before each letter
X009?ÿ?ÿ?ÿ STO F?ÿ?ÿ
X010?ÿ?ÿ?ÿ X/= 0??ÿ
X011?ÿ?ÿ?ÿ GTO X030?ÿ?ÿ?ÿ
X012?ÿ?ÿ?ÿ INPUT V
X013?ÿ?ÿ?ÿ (100xV)?ú36
X014?ÿ?ÿ?ÿ STO F?ÿ?ÿ
X015?ÿ?ÿ?ÿ X/= 0??ÿ
X016?ÿ?ÿ?ÿ GTO X030?ÿ?ÿ?ÿ
X017?ÿ?ÿ?ÿ INPUT R
X018?ÿ?ÿ?ÿ Rx16.5?ÿ
X019?ÿ?ÿ?ÿ STO F?ÿ?ÿ
X020?ÿ?ÿ?ÿ X/= 0??ÿ
X021?ÿ?ÿ?ÿ GTO X030?ÿ ?ÿ?ÿ
X022?ÿ?ÿ?ÿ INPUT C
X023?ÿ?ÿ?ÿ Cx66?ÿ?ÿ?ÿ
X024?ÿ?ÿ?ÿ STO F?ÿ?ÿ
X025?ÿ?ÿ?ÿ X/= 0??ÿ
X026?ÿ?ÿ?ÿ GTO X030?ÿ?ÿ?ÿ
X027?ÿ?ÿ?ÿ INPUT L
X028?ÿ?ÿ?ÿ (L?ú100)X66
X029?ÿ?ÿ?ÿ STO F?ÿ?ÿ
X030?ÿ?ÿ?ÿ VIEW F?ÿ
X031?ÿ?ÿ?ÿ RCL F?ÿ?ÿ
X032?ÿ?ÿ?ÿ 12?ÿ
X033?ÿ?ÿ?ÿ x?ÿ?ÿ
X034?ÿ?ÿ?ÿ 39.37?ÿ?ÿ
X035?ÿ?ÿ?ÿ ?ú?ÿ
X036?ÿ?ÿ?ÿ STO M?ÿ?ÿ
X037?ÿ?ÿ?ÿ VIEW M?ÿ
X038?ÿ?ÿ?ÿ RCL F?ÿ?ÿ
X039?ÿ?ÿ?ÿ 36?ÿ
X040?ÿ?ÿ?ÿ x?ÿ?ÿ
X041?ÿ?ÿ?ÿ 100
X042?ÿ?ÿ?ÿ ?ú?ÿ
X043?ÿ?ÿ?ÿ STO V?ÿ?ÿ
X044?ÿ?ÿ?ÿ VIEW V?ÿ
X045?ÿ?ÿ?ÿ RCL F?ÿ?ÿ
X046?ÿ?ÿ?ÿ 16.5?ÿ?ÿ?ÿ
X047?ÿ?ÿ?ÿ ?ú?ÿ
X048?ÿ?ÿ?ÿ STO R?ÿ?ÿ
X049?ÿ?ÿ?ÿ VIEW R?ÿ
X050?ÿ?ÿ?ÿ RCL F?ÿ?ÿ
X051?ÿ?ÿ?ÿ 66?ÿ
X052?ÿ?ÿ?ÿ ?ú?ÿ
X053?ÿ?ÿ?ÿ STO C?ÿ?ÿ
X054?ÿ?ÿ?ÿ VIEW C?ÿ
X055?ÿ?ÿ?ÿ 100
X056?ÿ?ÿ?ÿ x?ÿ?ÿ
X057?ÿ?ÿ?ÿ STO L?ÿ?ÿ
X058?ÿ?ÿ?ÿ VIEW L?ÿ
X059?ÿ?ÿ?ÿ RTN
Posted : June 1, 2018 8:02 am
Keeton
(@danielkeeton)
Thanks for the conversation formulas worked great.
Posted : March 19, 2024 7:46 am
