Detail pole target height errors - how to avoid them
7 Users
fobos8
(@fobos8)
Hi guys
I do a lot of house and garden surveys, picking up the topography for a architects who want to develop the site. I'd say on every survey I'll change the detail pole height (because of an obstruction) and forget to enter the new height on the data controller.?ÿ Doh!
How do you make sure you don't make this mistake?
Cheers, Andrew
Posted : October 11, 2018 12:31 pm
scott-ellis
(@scott-ellis)
Well you can either have the range pole all the way down or up, that way at least you know it is either/or. However that is still difficult to keep up with and some shots may need to be in the middle of the all the way up or down.
The best way is just to slow down and take the extra step of changing the rod height in the data collector, also bring a field book and write down the point number and rod height everytime you change the height.?ÿ
Posted : October 11, 2018 12:37 pm
Ethan
(@ethan)
Set the data collector to prompt you to enter the HR on every shot...it slows things down, but mistakes are rare.
Posted : October 11, 2018 1:29 pm
ken-salzmann
(@ken-salzmann)
I do a lot of those surveys too, and am constantly moving the prism up or down to be able to see it.?ÿ It has to become routine; you force yourself to remember.?ÿ Just like you remember to center the tribrach over the point, level the instrument, set zero on your backsight, and all the other things that you have to remember.?ÿ Just do it.
Ken
Posted : October 11, 2018 1:40 pm
That might be okay for a handful of shots, but when you're collecting 800 points a day it's not a reasonable solution.?ÿ You'd probably end up with more bad rods from fat-fingering than from forgetting to change it.
Posted : October 11, 2018 2:00 pm
Posted by: fobos8
Hi guys
Cheers, Andrew
Wait until it costs you enough time, money, and or grief. ?ÿThen you will learn to remember like we all have had to do over time. ?ÿI am afraid that this is just one of those ƒ??have to learn it the hard wayƒ? situations. ?ÿAlthough I do hope that I am wrong and someone will post a more helpful response than I have. ?ÿSorry.
EDIT: ?ÿExcellent question, by the way.
Posted : October 11, 2018 4:12 pm
lsitnj
(@lsitnj)
.. electronic device that detects the rh change and sends the info to the dc. I'm surprised that nobody invented something like this yet... or voice to text interface..
Posted : October 11, 2018 8:00 pm
Then you will learn to remember like we all have had to do over time. I am afraid that this is just one of those ƒ??have to learn it the hard wayƒ? situations.
FWIW, whenever I realize that I've taken some shots with the wrong HR, I immediately put a note in the raw data file identifying the scope of the problem as best I can recall.?ÿ Having some idea of when the problem started and ended helps narrow down the corrective action once back in the office.
Posted : October 11, 2018 9:10 pm
fobos8
(@fobos8)
I have the data collector fixed onto my pole just below where the height marks readings are on the pole. I always try to have the readings facing me as I data. So my aim is to keep looking at the height as I'm entering data.
I still screw it up though!
Posted : October 12, 2018 12:15 am
