you're writing a legal description.?ÿ you find this at a corner and want to reference it both on your survey and in your metes and bounds.?ÿ describe it.
Caprolite?
Replace it with something a little more substantial, and call it that.
found dirty human hand with pinkish tone often found on desk jockeys cupping 5" long 2" diameter iron chiseling maul.
Old weight for tall clocks? ?????ÿ
A window weight?
I have one as well.?ÿ What is this??ÿ
It's in the right spot but all of the other monuments from the 1950 subdivision were as described.
@flga & used as a plumb-bob
@flga that's what it looks like to me- corroded quite a bit.?ÿ i immediately thought counter weight either from a clock or a window or block and tackle.?ÿ mr. pinkhands (bless his heart) ain't seen enough yet in this life to have any better clue as to what it was.
@david-kendall that almost looks like a finial from a wrought iron fence.
If the end nearest the thumb is broken, then it could be part of a window weight.
@dougiei don't want to replace it.?ÿ it's unique to that corner and it fits.?ÿ the last survey (for the adjoiner) called it a 2" pipe.?ÿ ain't no pipe- it's solid.
An upright solid, round steel marker, 6? long with a top diameter of 2?, a diameter of 1.7? ?ÿat 5? inches below the top, and having a roughly 45 degree taper to a rather blunt point in the bottom inch.
Or for the sake of simpler text in the metes and bounds just "round steel marker, 6? long with a top diameter of 2? " and then just use the more lengthy, detailed description to the plat.?ÿ?ÿ
Ah, but is it steel, cast iron, or other form of iron?
