Data amount used while using a network rover
5 Users
pencerules
(@pencerules)
I will be getting a GRS-1 network rover soon, I am curious of the amount of data the rover will use a month. I am trying to determine the monthly plan through my cell phone company. Anyone who uses a RTN rover have any knowledge or idea of the monthly data used?
Thanks
Posted : October 17, 2012 10:37 am
mmm184
(@mmm184)
I should know this, I can't remember exactly, but I'm 99% sure our Trimble VRS rover uses less than 1 GB per month (Verizon MiFi). The good folks at Keynet figured it out for me once. 1 GB or less and you'll be safe (I think...:-D )
Posted : October 17, 2012 10:55 am
Pin Cushion
(@pin-cushion)
it depends on how much you use it, but the RTNs use VERY LITTLE data.
Posted : October 17, 2012 11:40 am
DavidALee
(@davidalee)
It uses very little. The smallest (cheapest) data plan they have available will be more than enough; especially if the only usage will be while using the RTN.
Posted : October 17, 2012 12:59 pm
pdop 1.0
(@pdop-10)
It is less than 1mb per hour of continuous use. On a tsc2 controller with access you can monitor the bytes streaming into the dc in real time.
If you stop for a break you can pause the data stream in a vrs survey.
Posted : October 18, 2012 11:26 pm
