Cut "X" Set (or) Mag Nail Set in concrete
15 Users
I know this has been covered many many times before, but the search function and I don't get along very well. I have been keeping a Dremel tool in my truck, but of course the day I need it the battery is weak, plus it never did drill holes for nails very well, really it only scratched an "x" more than cut one. I find that I only need to set an X or a nail in concrete maybe once a year. And I very rarely know it ahead of time, usually I realize it as I am walking up to set the monument.
So I think these Cobra style gas powered hammer drills are overkill for my needs. But maybe a small gas powered generator with an electirc hammer drill? Maybe something else?
What do you use / recommend?
Posted : 25/05/2015 8:33 am
We use a battery powered rotary hammer. The newer batteries hold a charge well. For once a year I would just carry a sharp chisel and a star drill...
Posted : 25/05/2015 8:42 am
(@sfreshwaters)
For around $850 plus the cost of bits you can have one of the best cordless impact drills around. I am always impressed when I use mine. It's a Bosch GBM36
Posted : 25/05/2015 9:04 am
Thank you. I never heard of a star drill before.
we use a hilti, battery powered, works like a charm.
If we are discussing property monuments we aren't allowed to do x's in the concrete, they have to be stamped monuments. I highly recommend doing that over an x, but if it's for traverse points or curb stakes, then the drill with a grinding disk attached works well also.
They are spendy but found one online for 1/2 price and have used it for years
Posted : 25/05/2015 9:05 am
You should be able to find the Bosch 36v Bulldog for almost have of the cost you posted.
I never had any problems with mine.
Posted : 25/05/2015 9:09 am
I carry a Ryobi ER-160 gasoline-powered hammer drill that I use on pretty much every survey. It's about the weight of a small chainsaw, is highly portable, and will drill a 5/8 in. x 20 in. hole into limestone without breaking a sweat. Unfortunately, they are no long available new. For light or occasional use, one of the new cordless hammer drills is probably a very good substitute.
Posted : 25/05/2015 9:11 am
For An Occasional X-Cut
use a commercial abrasive cutting wheel held in your hand. Broken in half is OK. Use a lath as a guide as it abrades the guide. If broken in half some duck tape on the broken edge assists in a firm hold.
Posted : 25/05/2015 10:30 am
(@peter-kozub)
Hi
I have been using this makita 5/8" hammer drill for pile driving and concrete layout
8-10 hours a day
For pile driving in winter for it seems you can pile drive in any weather so why not winter
at minus 20 C.
I have 6 battery packs and two chargers,two packs on charge, two in the survey bucket and two spares
for charging takes 45 minutes. With the long bit drill a hole in frozen ground and then pound in a 12 inch spike with a pin flag with a pile Number on it.
When concrete shows up i use the small bit and drill a hole in mud slab concrete
and drive the largest Mag nail 2 1/2 inch into the hole.
We might drill in 100 plus 12 inch spikes a day into frozen ground.
And about 20 mag nails a day into concrete. The carpenters like the mag mails because they look
nice and easy to find on dirty concrete.
I think the i have worn out 6-8 12 inch bits.
My survey buddy's borrow this makita hammer drill all the time for concrete and pile layout etc.
Peter
Posted : 25/05/2015 10:40 am
Will this work? It is on Amazon for $99. Is 18V enough? It says 1/2", but will it drill 1/4" holes into concrete for mag nails?
Makita XPH012 18V LXT Lithium-Ion Cordless 1/2-Inch Hammer Driver-Drill Kit with One Battery
Posted : 25/05/2015 11:41 am
(@hub-tack)
You don't use a star drill with an electric drill. You use it with a hammer.
Posted : 25/05/2015 11:45 am
(@stephen-ward)
Just about any hammer drill is capable of drilling holes in concrete for mag-nails. Larger bits, deeper holes, or bits with counter-sinks (for setting monuments flush) will require more power.
I used a similar Dewalt for years to set mag-nails in curbs for control. I moved up to a more robust drill when the city required a specific type of monument that had to be set with one of the counter-sink bits. Here's what I use now.
DEWALT DCH253M2
It drills about 2-3 times faster than my previous drill and also has a hammer only mode which lets me use it to chisel up monuments that are under a couple inches of asphalt.
Posted : 25/05/2015 12:07 pm
(@mvanhank222)
For once a year a standard 18 volt cordless drill will work buy the roatry/high speed concrete bit 1/32 or 1/16 smaller than the pk it won't be fast but no more than 30 seconds. I have drilled in plenty of PK nails like this if you want to countersink you have to be a little creative with bit selection I used a 1/8" bigger concrete hole saw bit than he head of the pk and knocked out the concrete inside the pk head.
Posted : 25/05/2015 12:33 pm
Excellent tips. Just the information I needed. Thanks (to everyone really).
Posted : 25/05/2015 12:35 pm
(@leegreen)
We use a 12v Cordless Makita 3 1/2" circular saw with concrete blade. The rpm are quite slow, but works much better than you think it will. It cuts concrete and stone easily, not just a scratch. On NYC sidewalks and curbs you will see a lot cuts made with saw like this.
Posted : 26/05/2015 2:04 am
(@end-of-the-road)
For an X we would carry a "Linoleum knife", hooked knife with yellow handle, but at the end of the blade it had a Hardened edge ( i believe it wasmore for scoring tile).
We also used the ole' lead plug and tack trick which required minimum drilling with a hand "star" drill into concrete (Hilti hammer drill if we were prepared)
Posted : 26/05/2015 3:17 pm
(@jimmy-cleveland)
I use a full size (7-1/4") Skill brand skill saw. I usually cut an "x" or arrowhead for corners or witness marks if needed in concrete, and witness them with a monument with my license number, and show it on my plat.
Thankfully, the states I am licensed in allow this, or allow us to set witness monuments.
I picked up the saw in a kit at CPO Outlets, it was a heck of a deal, and picked up an extra battery, and an extra charger for a total of three batteries and two chargers. I put a diamond blade in it, and it works great for the few times a year when I need it.
Posted : 26/05/2015 4:18 pm
(@marc-anderson)
I'll either use a cordless 18V drill with a masonry bit and set the nail in that hole but it's not countersunk and may chip off with a snowplow, or I'll use a small plug in power inverter in the truck to drive a standard 110V Dremel and cut crosses using standard Dremel cut off blades. The Dremel will cut nice small and deep crosses and won;t overdraw a smaller inverter.
Posted : 27/05/2015 5:39 am
