Custom surveying equipment
18 Users
richard-imrie
(@richard-imrie)
chris mills, post: 441643, member: 6244 wrote: cannot catch on anything. The top target is set back by 10mm. so it represents the tile face position at the depth being measured..This also means that measurements can be taken with timing pads in place, without the frame of the pad catching on the spirit level.
We "did" a pool recently, fortunately just before the pads were installed, to cut back the tiled ends to get within the 50m -0mm +30mm spec. (The photo below is just for show, we weren't actually surveying that bit - the RMT is on the spike again, which we used and the ends to mark out the cutting line).
Posted : August 12, 2017 12:34 pm
Richard Imrie, post: 441715, member: 11256 wrote: We "did" a pool recently, fortunately just before the pads were installed, to cut back the tiled ends to get within the 50m -0mm +30mm spec. (The photo below is just for show, we weren't actually surveying that bit - the RMT is on the spike again, which we used and the ends to mark out the cutting line).
The umbrella is obviously to help keep the solar panel from overheating.
Posted : August 12, 2017 3:08 pm
richard-imrie
(@richard-imrie)
Brad Ott, post: 441760, member: 197 wrote: The umbrella is obviously to help keep the solar panel from overheating.
Ironically, apparently solar panels work most efficiently when they are cool. We've actually ditched the panels and solar controllers - too much trouble with the low voltage cut out systems they have, turning our instruments off - now just direct hookup to a small car battery.
Posted : August 12, 2017 4:38 pm
squowse
(@squowse)
jim.cox, post: 441255, member: 93 wrote: We had to locate 234 driven wooden piles for an as-built survey.
Height was not needed, just position. But still it was going to take quite some time to locate each centre, level the prism and measure.
So I knocked up a device to quickly and easily locate the pile centres.
It worked really well.
Yup - an inverted waste basket with an attached prism
(sorry about the poor photo - the autofocus on my cheap camera doesn't like the wire mesh)
The piles turned out to be bigger than expected ( 300mm vs 250mm ) and it did not fit over them as planned, but it was easy to get the centre just sitting it on the cut ends.
So what's the best qizmo you guys have made?
Is your waste paper basket back in use in the office yet?
Posted : August 13, 2017 2:57 am
jimcox
(@jimcox)
squowse, post: 441826, member: 7109 wrote: Is your waste paper basket back in use in the office yet?
Sure is
Posted : August 13, 2017 11:22 am
chris-mills
(@chris-mills)
I hope you weren't carrying out the survey from the side of the pool as any residual instrument/prism error will double when you add the two sets of coordinates together to get the length.
I would always use three tripods set more or less down the centreline of the pool. Firstly I measure all those distances, to determine the prism/instrument constant under the days observation conditions, set that in the instrument and then measure each end from the opposite end tripod. Then any very residual errors cancel out.
The critical dimension is the "-0mm" one - nobody ever gets in a fuss over the "+30mm" since it is easy to pack out a timing pad. Looking at the photo, the timing pads seem to be Swiss Timing/Omega pads. Beware of the pad frame. They are stated to be 10mm pads, but the frame is around 13mm. so they don't sit back flush on the wall.The pads themselves have a +/-2mm tolerance so even if the pool is just in tolerance, once the pads are fitted it can be too short.
For those with interest in these matters, (or who can't get to sleep at night) the following go into the problems in detail although things have moved on a little since they were written.
http://www.scssurvey.co.uk/downloads/go5a.pdf
http://www.scssurvey.co.uk/downloads/go6.pdf
Posted : August 14, 2017 2:34 am
chris-mills
(@chris-mills)
Richard,
There was a New Zealand Surveyor, Mike Elliot, who I worked with on the London 2012 Olympic Pool. He would be able to give you all sorts of info on what can go wrong with pools.
Posted : August 14, 2017 2:44 am
richard-imrie
(@richard-imrie)
chris mills, post: 441974, member: 6244 wrote: I hope you weren't carrying out the survey from the side of the pool as any residual instrument/prism error will double when you add the two sets of coordinates together to get the length.
The issue with this one was that the pool had been built maybe ten years ago, and at that time had been surveyed to spec (and our survey showed it probably had been surveyed/built pretty good) but in the interim, someone had tiled the ends, the net result being that the tiles "protruded" into the 50m and they were uneven horizontally and vertically. We surveyed it and plotted average lines to bring it back to over 50m including allowance for the pads - from memory there was another issue to accommodate there, that being the compression of the pads when they are triggered, which needs to be taken into account in the length measurement - and then marked those as cut lines on the structure. We had reflector targets on the wall opposite the instrument to check for any issues. We checked the pool dimensions after it was cut back and it was within the tolerances - I think we aimed for 50m +20mm to allow for the pads/compression. This was about 3 years ago. The pool remained filled throughout the surveys and construction work.
Posted : August 14, 2017 2:57 am
chris-mills
(@chris-mills)
Richard Imrie, post: 441976, member: 11256 wrote: The issue with this one was that the pool had been built maybe ten years ago, and at that time had been surveyed to spec
I'm surprised they didn't empty the pool to carry out the tiling. Must have been interesting (and quite expensive - surely they didn't use the pool while the tiling was going on?)
There is a problem with older pools generally, in that many of them were surveyed before too much thought had been put into the overall interaction of wall tolerance, pad tolerance (and boom tolerance, if you are unfortunate to have one). Now when these are looked at more closely they are often found to be not quite what they were certified as.
Retiling is a common problem, as the original grout doesn't always get cut fully off, so the tiles then protrude. The most common cause of a pool failing on the length is the top nosing tiles, which always seem to ride forward as they are laid. This is more of a problem when there is an end gutter at water level with an upstand for the timing pad extending above. The lower nosings ride forward and then the whole of the upstand tiling is plumbed from that line
Posted : August 14, 2017 3:40 am
Astro backsight with 5/8-11/tribrach capability.
Posted : August 14, 2017 6:03 am
richard-imrie
(@richard-imrie)
chris mills, post: 441977, member: 6244 wrote: I'm surprised they didn't empty the pool to carry out the tiling. Must have been interesting (and quite expensive - surely they didn't use the pool while the tiling was going on?)
From memory the tiles were cut back and the face not re-tiled, just finished with a Sika product, so I think it must have been the case that the offending tiles were only down to the level of just below the water line. They put scaffolding in the pool with the workers standing on that in the water, using air driven tools. I do remember that as you say the top nosing tiles were forward of the ones below.
Posted : August 14, 2017 11:48 am
sireath
(@sireath)
chris mills, post: 441975, member: 6244 wrote: Richard,
Hi Chris, this just came in in time. I have a tender to measure some swimming pools to ensure that they comply with FINA standards. The Client was not really sure of some things. Thought I could ask you.
1. In the measurement of the pool, how do you properly define the centre of the lane of the start and finish. As I would expect a slight difference due to slant which will add mm's to the distance.
2. How do you measure the verticality of the wall, when the pool is filled.
Thanks and cheers
Posted : August 14, 2017 6:56 pm
chris-mills
(@chris-mills)
Sireath,
I'll assume that these are pools without a bulkhead to change the length - that makes things more complicated.
1) The requirement for length applies to the whole width of the lane and for depth between +300 to -800mm from water level. It's generally accepted that you take a grid of 9 points - left, centre, right at +300, water level and -800, hence 9 length readings in each lane. If timing pads are not in place then I would treat each lane rope set as reading for both lanes, but if pads are in place then you need to read 9 on each pad. I use a flat back target (the GDM RMT one) as this spreads the touching area over the tiles joints, hence you pick up any tile which is sticking out slightly. It would be easy enough to make a suitable backplate for any other type of prism.
I always use a station at each end of the pool. These are set using the tile lines as a guide to be square to the pool and close to central. Take this as a baseline zero and set the instrument to coordinates. Check read the Y value at the centre and outer lanes. If there is an obvious twist I adjust the Zero angle so that the far face appears to be more or less square from the three coordinates (assuming the face is straight!!).Then the instrument is pretty much square to the face when reading Zero (check again after adjusting in case you went the wrong way). Read the far station and put a coordinate and bearing on it.
Now when you read the faces you are reading coordinates, not distances, so all you need to do is take the difference between the two figures for the length, so you are not measuring skew distances. As well as booking the figures in the recorder I also write them down so I have an immediate visual check on the lengths - any problem and you can investigate immediately. Even if the figures are short ALWAYS complete the full set, so they can be used for remedial works.
Before I survey I normally do a "feel" inspection, running the palm of my hand across the full area of tiles to be surveyed, which quickly identifies any protruding tiles you might need to additionally check. Make sure the nosing tiles do not protrude. A visual look along the face will also tell you a lot.
2) Verticality. Measure when empty! If you can't then the device I illustrated earlier enables you to measure it over the depth required. Use the spirit level unit to measure the -800 depth and then a standard target will do for water level and +300mm.
When pricing up, if any of the pools are indoors then allow half an hour for the instrument and prism to acclimatise to the temperature and humidity in the pool area. You'll need that time in any case to assess the job and pick suitable spots for the stations. Also, allow for a three station calibration set up on site prior to observing. Remember that "-0mm" means exactly that.
Use my contact details if you need any more information - it'll probably get a bit too technical for general browsing here.
Posted : August 15, 2017 1:04 am
half-bubble
(@half-bubble)
Once upon a time the boss tacked a Target card to a chunk of 4x8 long enough to straddle a street Mon case. The idea was to put a plumb bob on the dimple and align the card center with the string.
Posted : August 15, 2017 7:57 am
half bubble, post: 442223, member: 175 wrote: Once upon a time the boss tacked a Target card to a chunk of 4x8 long enough to straddle a street Mon case. The idea was to put a plumb bob on the dimple and align the card center with the string.
That brings back a flood of memories.
Back in 1970, one of the first things I was taught was how to set a backsight.
We had company business cards with a red and white target on the back. We stuck a nail thru the top and bottom to use for backsights on 36" lath, plumbed above the traverse point. For well monuments we stuck them in a 1x2 guard stake, and used the lid to keep them from blowing away... usually with a cone, but not always.
One evening the boss announced that he had to pay for a flat repair, the nail with business card/target was still in the tire. From then on we used cup tacks to fasten the target to the 1x2.
I would not like to put something big like a chunk of 4x8 in the road without a bunch of cones, somebody could get hurt.
PS: lath, 1x2s, nails, , cup tacks (on a tack ball), targets, plumb bobs, etc. were always at hand.
"Don't get out of the car without them!"
I guess not so much any more.
Posted : August 15, 2017 8:46 am
Peter Ehlert, post: 442237, member: 60 wrote: One evening the boss announced that he had to pay for a flat repair, the nail with business card/target was still in the tire.
Although I didn't witness the event, I was told of the time a representative from the local electric utility arrived at my former employer's office and placed on the boss' desk a section of power pole that had been notched with a chainsaw. In the notch was a nail and paper target with the company name on it. Along with the section of pole was an invoice for pole replacement.
Posted : August 15, 2017 9:18 am
