CFedS boundary certificates
9 Users
DWolfe
(@dwolfe)
Fellow CFedS,
I'm being asked by another firm which doesn't have a CFedS on staff to review their work and sign off on a Land Description Review and Chain of Survey certificates. I'd also be reviewing a Record of Survey (performed by another PLS) to facilitate a Fee to Trust conveyance. In reading the certifications I'd be signing and the "Certified Federal Surveyor Program Standards of Practice Handbook" (see Chapter III, section C) it doesn't appear to me that I could truthfully sign these certificates with regards to "Responsible Charge". Now this firm has been using another CFedS but I'm closer which would save money on site visits etc. Your thoughts?
TIA,
Doug
Posted : September 25, 2013 12:25 pm
Dave Ingram
(@dave-ingram)
Among other things I'd worry about if that firm had a COA in the state in question, whether you are listed as the responsible surveyor on another COA, etc.
Then there is the matter of appropriate supervision, etc.
Posted : September 25, 2013 12:42 pm
WA-ID Surveyor
(@wa-id-surveyor)
Sounds like a recipe for a potential disaster, if not a violation of CFED or State codes. How can you be in responsible charge after the fact?
Posted : September 25, 2013 1:02 pm
tyler-parsons
(@tyler-parsons)
I think Big Trouble.
If the other CFedS did the work (research, certifications, and survey), why is he not signing off on the work.
If the company did the work in-house and don't have a CFedS on staff or retainer, there's no telling whether what they've done is correct AND COMPLETE.
I would not touch this unless they give you complete authority to do the research and survey work which needs to be done. You have the option to accept their survey if it meets your and the BLM standards but I'd check everything - basically a re-do. I'd guess they are trying to avoid this.
Good Luck!
Tyler Parsons, CFedS #1001
Posted : September 25, 2013 1:11 pm
foggyidea
(@foggyidea)
Although my CFedS is temporarily suspended (I need CEU's) I think that the first two items are OK> That is simply reviewing documents as to the quality of description and whether it is sufficient to place on the ground. No field work is required, if I remember correctly.
Posted : September 25, 2013 1:13 pm
DWolfe
(@dwolfe)
Don,
Here's the certificate for the LDR:
Certification: This Land Description Review correctly represents the records and documents compiled by me or under my direct supervision in conformance with the requirements of the Department of the Interior Standards for Indian Trust Lands Boundary Evidence, of the tract(s) or parcel(s) of land identified above.
The COS certificate is exactly the same. My problem is the words ...compiled by me or under my direct supervision...
Doug
Posted : September 25, 2013 1:35 pm
DWolfe
(@dwolfe)
Thanks Tyler. They have no CFedS on staff. Your thoughts and mine match exactly 😉
Posted : September 25, 2013 1:39 pm
DWolfe
(@dwolfe)
I couldn't agree more. Thanks for the input.
Posted : September 25, 2013 1:40 pm
foggyidea
(@foggyidea)
I assumed that you would do that part of the review and research, just no field work.
I stand corrected.
Posted : September 25, 2013 1:54 pm
DWolfe
(@dwolfe)
Not sure what COA is but I assume it's the professional in charge of the office which they have. I'm a solo operator so I'm in charge of everything! Thanks for your input.
DWolfe
(@dwolfe)
They tell me that they've done everything and just want me to review. I have a problem signing the certificate given that scenario.
Posted : September 25, 2013 1:56 pm
Looks like the other surveyor just got some more work.
Posted : September 25, 2013 2:37 pm
Larry P
(@larry-p)
Sounds like it is time to go back to them and ask:
what part of
...compiled by me or under my direct supervision ...
are y'all struggling with?
Unless and until you do or personally supervise the work described in the certificate, you shouldn't risk your license saying you did.
As for the Dave Ingram comment ... COA = Certificate of Authorization. AKA, properly licensed to do the work in that jurisdiction.
Sounds like you smelled this rat already and just needed some attaboy's. Trust your gut and be very wary.
Larry P
Posted : September 25, 2013 2:44 pm
Yeah go get their own CFedS 🙂
Posted : September 25, 2013 2:45 pm
DWolfe
(@dwolfe)
You hit the nail square Larry. Thanks to all for responding.
Posted : September 25, 2013 3:30 pm
dmyhill
(@dmyhill)
This is an interesting problem.
Responsible charge is difficult to argue in this circumstance, and a overall issue for all surveyors to consider.
How can we deal with the situation of long term or legacy projects, and the retirement, death, or employment changes among key employees?
If you are one day from signing a 200 lot plat, and the one PLS in your engineering firm quits, are you going to check every corner and revisit every monument?
Not really on topic, but it seems the issue here isn't CFedS specific, really. Responsible charge is an issue and topic for us all.
David
Posted : September 26, 2013 12:12 pm
