OK, I am sure this has been covered before but there are so many Carlson subject lines that I can't find it - so.
Carlson 2011 inside AutoCAD C3D 2009
Everything was working fine and now the program will only let me "pick" one item at a time. If I go to pick several lines to move, rotate or edit I am allowed to pick only one. If I pick one then try to pick another the first is removed from the que. I haven't changed anything that I can think of but I did get an update recently so that may be it.
I am sure that this is just a setting, but which one? Sorry to be dense but I rarely get fancy with the software or change anything, just another tool, trying to get some plans out.
I would appreciate any input.
Thanks
T.W.
Try the setvar "pickadd". Set to 1
Have you rebooted the software? If so, try shutting down and then rebooting the computer and then the software. Sometimes a hard boot is needed. If this don't work, a call to Carlson is needed.
Mike:
Worked like a charm! Thanks, so many variables I don't know how we are suppose to know what they all are and still have time work.
T.W.
Terry:
Thanks for the reply. I did close the program and restart it but that was no help, the setvar worked.
I am all set until next time.
T.W.
*** More Carlson Help needed***
since your problem is solved......
Something changed My Carlson / ACAD 2009 so that every time I select something, the command line info appears at the cursor and partially obscures the drawing. It's getting kind of annoying and I can't figure out how to turn it off.
Check the DYN button on the bottom of the drawing screen, or check and make sure it's not checked!
thanks foggy
that did it!
this board is awesome.
