Your restoration projects are always so interesting. One of these days I will make to drive out to participate. Thanks for sharing.
Tidy, tidy work there J.P. I applaud your passion and your meticulous ways. We all should take note of your requirement for detail.
Very impressive.
We love your work, and your writeups too. Thank you.
Cheers,
m & h
Wow. Really nice work!
A++
Always very cool to see, especially considering how many others would just as soon roll over it with a dozer.
Admiration. I aspire to do this type of work someday.
What type of glue do you use for stone?
Daniel Ralph, post: 378444, member: 8817 wrote: Admiration. I aspire to do this type of work someday.
I used a high grade construction adhesive Liquid Nails. The weight of the top stone provided a lot of pressure to bond them together. Then used a high grade silicone around the outside cracks after placing the angle irons on the sides.
Beautiful work.
How well did the elevation of the stone match when you did the 3-wire run?
The original mark is now technically destroyed. Will you be filing a RESET on it to get a new PID, or does that process even work nowadays?
http://www.ngs.noaa.gov/cgi-bin/ds_mark.prl?PidBox=NN0214
Two thoughts about stability - Is packed sand sufficiently stable against settling? Will the concrete around the stone lift it up when water freezes under the concrete?
