Bad GPS day on 3-14?
7 Users
j-t-strickland
(@j-t-strickland)
Man, I couldn't get a fix in the wide open from about 11am-2pm in Northeast Mississippi yesterday, with GPS and GLONASS. I finally packed up and went in.
Anybody else?
Posted : March 15, 2013 6:39 am
Artie Kay
(@artie-kay)
Hi JT, doesn't look if there was anything out of the ordinary on the spaceweather front,
http://www.swpc.noaa.gov/rt_plots/kp_3d.html
What we get here in the UK sometimes is the military playing around with jamming, ok if you're notified, but the message doesn't always get out to everyone.
Posted : March 15, 2013 6:58 am
Mitch
(@mitch)
I believe you may need to dissable Glonass [or if you know which satellite(s)] during that period, as that has worked for us. I believe one or more satelittes are bad. I'm not smart enough to know more about it, though.
Posted : March 15, 2013 7:24 am
Sat Al
(@sat-al)
There was nothing wrong with GPS. Sometimes GLONASS sats burp, but shouldn't cause this problem.
Sun spots are not the problem.
99% of the time, this is a problem with a specific manufacturer. Check with them for a firmware update and see of others with the same model/firmware were having the same problem.
> Anybody else?
Posted : March 15, 2013 9:16 am
Mike Mac
(@mike-mac)
I have had to turn of glonass a few times to get a fixed position...also a reboot of the DC does the trick sometimes.
Posted : March 15, 2013 9:30 am
j-t-strickland
(@j-t-strickland)
Thanks for the replies. Apparently my bad.
I cleared the NV Ram, and today went a lot smoother. btw, I have topcon hiper lite + receivers. They haven't released a firmware update for quite some time. I think they're concentrating on their newer receivers. They used to update the firmware pretty regular, but not anymore.
Posted : March 15, 2013 11:24 am
dms330
(@dms330)
I have the same receivers and sometimes you have to disable the GLONASS sats one at a time until you get a fix, like stated above.
Licensed Land Surveyor
Posted : March 15, 2013 7:00 pm
Old School Surveyor
(@old-school-surveyor)
I run a leica viva smartnet 08 seris on 90% of the work I do regarding construction lay-outs. The problem someone said they had between 11-2 pm is not unusal anywhere in the country. That is a prominent spike period. I usually have this problem when im running my unit on a grid coord. system and not so much when using a surface system which is easy to convert back and forth with using leica system software. To make a long story short I did have problems using both coordinate systems on this day. I finally gave up on the gps and pulled out the old trusty total station and ranger data collector and finished the project the old school way.
Posted : March 17, 2013 2:57 pm
