AS BUILT POINTS WITH ROBOTIC TOTAL STATION
9 Users
nomee
(@nomee)
Hi Every One
Yesterday I Did Some as Built Points with Top Con Robotic Total Station
I Set Up My Total Station with Resection 0f 4 Reflector Targets but When I Make the Drawing All points Shifted Around 40mm to One Side
I don‰Ûªt Know What Wrong If Some One Answer I Applicate.
Posted : July 1, 2016 9:43 am
Moe Shetty
(@moe-shetty)
naveed, you should provide some more details, as i don't think we can help without them
Posted : July 1, 2016 9:55 am
Check the defaults on your download program.
It may be set to transpose the coords by that amount.
Posted : July 1, 2016 10:31 am
Kris Morgan
(@kris-morgan)
Try exporting the points only, and not raw data. It's raw data file and your software may not be working well together.
Posted : July 1, 2016 10:48 am
squowse
(@squowse)
Moe Shetty, post: 379674, member: 138 wrote: naveed, you should provide some more details, as i don't think we can help without them
that would make it too easy.
Posted : July 1, 2016 10:51 am
I'm thinking maybe a problem with prism constants.
SO, you resected to 4 points. What were the residuals? Could be you had some bad control pulling the whole thing out of whack.
Posted : July 1, 2016 10:52 am
squowse
(@squowse)
Damn I was going to guess prism constants. OK I'm going to guess - "the structure has been built 40mm out of place".
Posted : July 1, 2016 10:53 am
scott-ellis
(@scott-ellis)
What data collector were you using? Sometimes you have to change the prism offset in the instrument as well as the data collector.
Posted : July 1, 2016 11:42 am
chimeric
(@chimeric)
first thing i'd do is check the resection azimuths and BS azimuth in the raw data. more often than not your (my) problem is found there.
Posted : July 1, 2016 11:48 am
I love this place. Survey angels. You guys are good people.
Posted : July 1, 2016 4:28 pm
