2008 CARLSON STANDALONE ?
(@dane-ince)
IN THE LAYER DIALOG BOX PLOTSTYLES IS GRAYED OUT AND NOT SELECTABLE. ANHY WAY TO CHANGE THIS
THANKS FOR YOUR HELP
Posted : November 15, 2011 7:49 pm
(@stephen-ward)
Most likely your drawing template has been set to use "color dependent plot styles" rather than "named plot styles". The setting is under Tools, Options, Plotting. Start a new drawing and copy everything from the first drawing into the new drawing. There's probably a more elegant way to convert an existing drawing but I do not know it.
The above is based on AutoCAD 2000, hopefully it is the same in 2008.
Posted : November 15, 2011 8:05 pm
(@doug-crawford)
I don't know about Carlson, but try "CONVERTPSTYLES "
Posted : November 16, 2011 2:43 am
(@brian-nixon)
Do you have any plotstyles saved?
Or is the directory that contains the plotstyle files correctly referenced?
Posted : November 16, 2011 6:15 am
