2003 typo????
18 Users
(@daniel-s-mccabe)
It was brought to my attention that I made a typo on a bearing call for a plat that was issued in 2003.
The attorney that caught the error has requested that I correct the plat and send him a copy so that he can record the survey with the act of correction.
At this point I do not see a problem with that, and have made a note explaining what had happened and that no additional field work had been performed, but I thought that I should run it by the "board" and see if my thoughts are wrong.
Thanks,
D
Posted : September 20, 2011 5:05 am
(@joe-the-surveyor)
While I'll almost always say 'it depends', I've done the same thing. I add a revision date, and add the note..no big deal in the end.
Posted : September 20, 2011 5:07 am
(@deral-of-lawton)
Sounds fine to me as long as the note shows clearly that the change was only to correct a minor scrivenor's error and nothing else on the face of the plat.
Posted : September 20, 2011 5:14 am
 RFB
(@rfb)
N-E instead of S-W? or a "real" typo?
Posted : September 20, 2011 5:25 am
(@daniel-s-mccabe)
No, SW when it should have been SE.
Posted : September 20, 2011 5:26 am
(@newtonsapple)
I think the bearing was labeled N91°W...
Posted : September 20, 2011 5:27 am
(@daniel-s-mccabe)
No, that would have been on YOUR plat. 😉
Which reminds me of the old days, telling the IM to turn 89-59-60.
Posted : September 20, 2011 5:30 am
I remember the DOS C&G software would sometimes spit angles like that out in the stakeout report.
Posted : September 20, 2011 5:36 am
(@darrell-andrews)
Is this a survey or a subdivision? The term "plat" gets thrown around in more than one way it seems. Are you in a recording state? If it is a subdivision, then it would be simple to correct with an affidavit.
Posted : September 20, 2011 5:39 am
Do not feel bad. It happens. I did the same thing a few months ago. Thankfully it was caught at the courthouse, but, not until after the deed and mortgage had been filed. I paid for the refiling of the deed and getting the title company happy. No big deal.
About 10 years ago I discovered a similar error made by a then-deceased surveyor about 30 years earlier on the boundary of a 30 lot subdivision around a small lake. I was surveying the remainder tract that adjoined the subdivision which had changed hands several times in those 30 years.
Posted : September 20, 2011 5:41 am
Around here, everything is a plat whether one tract or 50.
Posted : September 20, 2011 5:42 am
(@daniel-s-mccabe)
No, not a recording state. To me, a plat, is a plat, is a plat.
(@dan-rittel)
Can you file an affidavit rather than a new plat drawing?
Posted : September 20, 2011 5:44 am
(@daniel-s-mccabe)
I thought that would be better, but the attorney is requesting a corrected plat.
Posted : September 20, 2011 5:48 am
(@darrell-andrews)
Around here, a plat refers to a subdivision of land for the purpose of recording.
If that is the same for you, then an affidavit would be the easiest solution.
Posted : September 20, 2011 5:54 am
(@darrell-andrews)
Just for one screwed up Letter of the alphabet?????
Posted : September 20, 2011 5:55 am
(@daniel-s-mccabe)
yep.
Posted : September 20, 2011 5:57 am
(@darrell-andrews)
How long has he been practicing? Seems like the request of an inexperienced individual. I'd press for an affidavit.
Posted : September 20, 2011 6:09 am
(@sir-veysalot)
And If I don't?
Posted : September 20, 2011 6:31 am
(@perry-williams)
the bright side
At least with a Bearing error, a user of your plan would most likely notice the error and be able to figure out it was a simple East-West error. No such luxury with a coordinate error.
Posted : September 20, 2011 6:56 am
