Windows 7 Sleep Mode causing me to have to re-log in
(@frank-willis)
Suddenly my computer with Windows 7 Professional goes into the screen saver mode after 10 minutes, but instead of screen saver, it logs me off, and I have to enter password to resume. I don't think I accidentally change anything. Can anyone tell me how to get it back to where it doesn't log me off when I am not using it?
Posted : June 7, 2013 10:45 am
 John
(@john)
Blame it on gremlins or the biggest virus of them all.... windows.
Try the following (hope it's the right solution):
press the start button
in the search area, type "screen saver"
look for and select "set screen saver password"
this should bring up a new window.
Look for a check box labeled "on resume display logon screen" and uncheck the box
Posted : June 7, 2013 11:34 am
 BigE
(@bige)
I think you need to check your power savings settings.
Sleep mode is different than screen saver.
Posted : June 7, 2013 4:03 pm
(@doug-crawford)
If it's a 'screen saver problem', John Got it.
If it's a 'requiring you to 'log-on', Eric has it.
search for 'power options'
Require a password on wake up, select "don't require password on wake up",
this may cause a security risk, as anyone can wake it up and have your data available.
Posted : June 8, 2013 5:24 pm
 John
(@john)
What I had attempted to get at is that there are power options under the screen saver function......:-)
Posted : June 9, 2013 2:38 am
(@frank-willis)
THANKS ALL!!!!!!!!!!!:-D
Posted : June 10, 2013 5:54 am
