Does the SPS882 work with Trimble Access? I recall an article about compatibilty with Survey Controller if the user has a Trimble supplied code, but I'm unable to find documentation regarding Access.
Posted : June 22, 2015 7:46 pm
Construction instruments unlock code will be required on a "survey" TSC3. Cost was £200 for me.
If you have bought Access for a yellow "construction" TSC3, then this will have been included.
Posted : June 23, 2015 12:19 am
If you run 2014.20 or higher you no longer need the construction instruments code
Posted : June 23, 2015 1:22 am
OZEE, post: 323873, member: 8262 wrote: If you run 2014.20 or higher you no longer need the construction instruments code
Really? I have just wasted my money then.
I should have tested first.
Posted : June 24, 2015 12:18 am
Belated update - I got a refund, thanks!
Posted : June 30, 2017 1:01 am
