LABELING BUILDING DIMENSIONS IN CIVIL 3D
2 Users
BobM
 BobM
(@bobm)
In Carlson there is a command in survey text to label a building (labels inside of closed polyline). Is there something like this in Civil 3D? Thanks.
Bob
Posted : June 21, 2015 11:30 pm
Dan Patterson
(@dan-patterson)
Create and modify a label style as you desire it to appear.
If it comes up on the outside of the polyline, you can us PE or polyline edit command to "reverse" the direction of the line.
If you don't want to reverse the line you can select the label and "flip" it under the right-click options.
I would probably choose the first method as it will handle all of labels at once.
Posted : June 22, 2015 5:58 am
BobM
 BobM
(@bobm)
Thanks Dan
Posted : June 22, 2015 11:02 am
