I am out of town, and have just lost my survey menus in the IntelliCAD engine Carlson Survey.
Against instruction, I have been opening and using a Template DWG since 2013, and have never had any problems...
Tonight, my survey menus are gone, (I think the software is reverting to DEMO mode), and Invalid Popup Reference is automatically entered in the command line, four times, before start up comes to rest.
Any easy way to get around and fix this without my code keys in hand?
-B
I know it's not an answer but, for a possible reason, I would think "windows update". Killed me a year ago and the only cure was a re-install.
You might try the RESETUI (Reset User Interface) command key-in. I don't recall if the command was available in that version of Carlson but it might do the trick if it is in there. If it isn't in there and results in an Unknown Command, you might try right-clicking on your Command window and choosing Options. Visit the Profiles tab and Reset your Carlson profile. You'll probably have to exit from the software and re-start it (and ultimately reset toolbars, etc), but this would be much simpler than re-installing (IMHO).
I hope this information helps.
