What project management software do you guys use, or even wish you could use, for your land surveying or engineering firms?
Our current project management software isn't working for us so we're on the hunt for something that can log our project details (e.g. project number, address, block and lot, acreage, etc.), timesheet hours for billing, and client details primarily. Trouble is, I'm not seeing a lot of software that is well suited for land surveying businesses (i.e. which have fields for block, lot, acreage, etc.) and also am a little overwhelmed by all the software out there.
The places I've worked used basically a spreadsheet program, either Excel or a custom program that did something similar.
Info-Retriever is what my previous employer uses.?ÿ It will connect with Quickbooks and you can add custom fields if there is something you want to add as database fields.
@va-ls-2867 Thank you! I'll have a look at this.
@bstrand Thank you! Good to know.
