Star*net with Carlson converter help needed.
2 Users
Some time ago, I was struggling to make sense of the last portion of my control network I shot before winter shut me down. Here's the thread:
https://surveyorconnect.com/threads/need-help-troubleshooting-an-rw5.324471/#post-348883
At that time I was using TraversePC as my "rw5 to Star*net dat" converter, and I think something funky happened to the data along the way. I then started to try to manually write the dat file, and gave up because of all the typos. In a related thread, fellow Beerlegger Royevrus had Starnet and the Carlson Converter, offered to translate another related rw5 into a dat directly.
Would someone (who uses Star*net, and has the Carlson converter), be so kind as to take a whack at this one?
Many thanks in advance.:stakeout:
JB,NM800-1000-1100,DT11-27-2015,TM12:59:43
MO,AD0,UN2,SF1.00000000,EC0,EO0.0,AU0
--SurvCE Version 2.07
--CRD: Alphanumeric
--VT NAD83
--Equipment: Topcon GTS/GPT Series
--TS Scale: 1.00000000
--EDM Mode: Fine
-- Notation: At-From-To
-- 800-700-1000
--Set Collection with Obs Order 123...321...
OC,OP800,N 427882.51500,E 1618086.71400,EL1086.810,--
LS,HI5.0000,HR5.0000
BK,OP800,BP700,BS9.1146,BC0.0000
BD,OP800,FP700,AR0.0000,ZE98.1044,SD,--
FD,OP800,FP1000,AR194.3844,ZE78.2021,SD300.373000,--
FR,OP800,FP1000,AR14.3810,ZE281.3929,SD300.373000,--
BR,OP800,FP700,AR179.5910,ZE261.4744,SD,--
--SS,OP800,FP700,AR0.0000,ZE98.1130,SD0.000000,--
--SS,OP800,FP1000,AR194.3852,ZE78.2026,SD300.373000,--
-- 1000-800-1100
OC,OP1000,N 427613.44754,E 1617967.79507,EL1147.514,--
BK,OP1000,BP800,BS23.5038,BC0.0000
BD,OP1000,FP800,AR0.0000,ZE100.5920,SD300.355000,--
FD,OP1000,FP1100,AR65.2926,ZE97.5040,SD202.135000,--
FR,OP1000,FP1100,AR245.2919,ZE262.0852,SD202.135000,--
BR,OP1000,FP800,AR179.5947,ZE259.0010,SD300.354000,--
--SS,OP1000,FP800,AR0.0000,ZE100.5935,SD300.354500,--
--SS,OP1000,FP1100,AR65.2929,ZE97.5054,SD202.135000,--
-- 1000-800-14A
BD,OP1000,FP800,AR0.0000,ZE100.5927,SD300.346000,--
LS,HI5.0000,HR6.0000
FD,OP1000,FP14A,AR137.0728,ZE85.2103,SD223.448000,--
FR,OP1000,FP14A,AR317.0728,ZE274.3836,SD223.446000,--
BR,OP1000,FP800,AR179.5956,ZE259.0011,SD300.345000,--
--SS,OP1000,FP800,AR0.0000,ZE100.5938,SD300.345500,--
--LS,HI5.000000,HR6.000000
--SS,OP1000,FP14A,AR137.0730,ZE85.2113,SD223.447000,--
--LS,HI5.000000,HR5.000000
-- 1100-1000-800
OC,OP1100,N 427615.77076,E 1618168.02320,EL1119.912,--
BK,OP1100,BP1000,BS269.2007,BC0.0000
BD,OP1100,FP1000,AR0.0000,ZE82.1245,SD202.144000,--
FD,OP1100,FP800,AR73.4837,ZE96.0302,SD280.928000,--
FR,OP1100,FP800,AR253.4834,ZE263.5619,SD280.926000,--
BR,OP1100,FP1000,AR179.5953,ZE277.4711,SD202.139000,--
--Warning: Vertical Angles to foresight differ by 0‰ö?00'39".
--SS,OP1100,FP1000,AR0.0000,ZE82.1247,SD202.141500,--
--SS,OP1100,FP800,AR73.4839,ZE96.0321,SD280.927000,--
--1100-800-14A
BK,OP1100,BP800,BS269.2007,BC0.0000
BD,OP1100,FP800,AR0.0000,ZE96.0241,SD,--
FD,OP1100,FP14A,AR227.4810,ZE79.3717,SD252.364000,--
FR,OP1100,FP14A,AR47.4809,ZE280.2216,SD252.364000,--
BR,OP1100,FP800,AR179.5957,ZE263.5706,SD,--
--SS,OP1100,FP800,AR0.0000,ZE96.0247,SD0.000000,--
--SS,OP1100,FP14A,AR227.4811,ZE79.3730,SD252.364000,--
--1100-1000-14A
BD,OP1100,FP1000,AR0.0000,ZE82.1235,SD202.140000,--
FD,OP1100,FP14A,AR301.3652,ZE79.3724,SD252.365000,--
FR,OP1100,FP14A,AR121.3658,ZE280.2204,SD252.363000,--
BR,OP1100,FP1000,AR180.0004,ZE277.4720,SD202.141000,--
--Warning: Vertical Angles to foresight differ by 0‰ö?00'32".
--SS,OP1100,FP1000,AR0.0000,ZE82.1238,SD202.140500,--
--SS,OP1100,FP14A,AR301.3653,ZE79.3740,SD252.364000,--
--1100-1000-1200
BD,OP1100,FP1000,AR0.0000,ZE82.1148,SD202.178000,--
FD,OP1100,FP1200,AR110.0422,ZE102.0821,SD114.352000,--
FR,OP1100,FP1200,AR290.0414,ZE257.5115,SD114.350000,--
BR,OP1100,FP1000,AR179.5955,ZE277.4756,SD202.176000,--
--SS,OP1100,FP1000,AR0.0000,ZE82.1156,SD202.177000,--
--SS,OP1100,FP1200,AR110.0421,ZE102.0833,SD114.351000,--
--1100-800-1200
BK,OP1100,BP800,BS343.0252,BC0.0000
BD,OP1100,FP800,AR0.0000,ZE96.0146,SD280.915000,--
FD,OP1100,FP1200,AR36.1454,ZE102.0809,SD114.352000,--
FR,OP1100,FP1200,AR216.1510,ZE257.5039,SD114.351000,--
BR,OP1100,FP800,AR180.0010,ZE263.5642,SD280.915000,--
--Warning: Vertical Angles to foresight differ by 0‰ö?01'12".
--SS,OP1100,FP800,AR0.0000,ZE96.0232,SD280.915000,--
--SS,OP1100,FP1200,AR36.1457,ZE102.0845,SD114.351500,--
--1200-1100-800
OC,OP1200,N 427721.21123,E 1618205.17036,EL1095.859,--
BK,OP1200,BP1100,BS199.2427,BC0.0000
BD,OP1200,FP1100,AR0.0000,ZE77.4608,SD114.372000,--
FD,OP1200,FP800,AR124.2900,ZE91.3853,SD200.476000,--
FR,OP1200,FP800,AR304.2847,ZE268.2052,SD200.473000,--
BR,OP1200,FP1100,AR179.5956,ZE282.1344,SD114.372000,--
--SS,OP1200,FP1100,AR0.0000,ZE77.4612,SD114.372000,--
--SS,OP1200,FP800,AR124.2856,ZE91.3901,SD200.474500,--
Posted : February 19, 2016 2:57 pm
Royevrus
(@royevrus)
V 800-700 98-11-30.00 5.000/5.000
M 800-700-1000 194-38-52.00 300.3730 78-20-26.00 5.000/5.000
DV 1000-800 300.3545 100-59-35.00 5.000/5.000
M 1000-800-1100 65-29-29.00 202.1350 97-50-54.00 5.000/5.000
DV 1000-800 300.3455 100-59-38.00 5.000/5.000
M 1000-800-14A 137-07-30.00 223.4470 85-21-13.50 5.000/6.000
DV 1100-1000 202.1415 82-12-47.00 5.000/5.000
M 1100-1000-800 73-48-39.00 280.9270 96-03-21.50 5.000/5.000
V 1100-800 96-02-47.50 5.000/5.000
M 1100-800-14A 227-48-11.00 252.3640 79-37-30.50 5.000/6.000
DV 1100-1000 202.1405 82-12-37.50 5.000/5.000
M 1100-1000-14A 301-36-53.00 252.3640 79-37-40.00 5.000/6.000
DV 1100-1000 202.1770 82-11-56.00 5.000/5.000
M 1100-1000-1200 110-04-20.50 114.3510 102-08-33.00 5.000/5.000
DV 1100-800 280.9150 96-02-32.00 5.000/5.000
M 1100-800-1200 36-14-57.00 114.3515 102-08-45.00 5.000/5.000
DV 1200-1100 114.3720 77-46-12.00 5.000/5.000
M 1200-1100-800 124-28-55.50 200.4745 91-39-00.50 5.000/5.000
Posted : February 25, 2016 9:48 am
Thank You very much!
That came in flawlessly...with no edits at all. I've really got to work on getting the full program soon.
Thanks again.
Posted : February 25, 2016 6:32 pm
