We did a Traverse in Leica Captivate with a per setup scale factor and are trying to process it in Infinity. When we process the traverse it gives a closure worse than I would expect and it is showing a scale factor of 1.002xxxxx. The scale factor here should be 0.9999002xxx. Coordinate systems and units are all correct.
Why is it showing me this incorrect scale factor and is (as I assume) affecting the measurements?
This software is driving me crazy....
Sent from my SM-G935V using Tapatalk
Hmm,
Are you running an adjustment? there could be some strange settings under "Advanced Terrestrial Parameters"
can you upload a screen shot of you your Coordinate system manager with your coordinate system highlighted.
Correct elevations? An incorrect or assumed elevation will affect the combined scale factor.
SHG
