intellicad and shape files
spledeus
(@spledeus)
i have one station running intellicad and i installed it on my machine with the hope of switching over.
i have custom shapes and custom linetypes with those custom shapes that work just fine in Acad.
i have issues loading the shape file into intellicad. i can get 3 of the special linetypes to work on my machine and none to work on the other.
i don't mind recoding the shapefile if i must, but i need some guidance. i don't mind recoding the linetype file either.
hopefully they will still work in Acad...
thoughts, ideas, suggestions?
Posted : May 21, 2013 12:45 am
callen
(@callen)
To transfer custom linetypes from another software I found a lisp routine with a web search that showed me where the ".lin" file was on an autocad machine. Open with notepad and it shows all linetypes including custom linetypes. Then I used it to find the .lin on the intellicad machine. Cut/Paste custom linetypes into the file your intellicad machine. Then they show up in your list of line types. Probably an easier way, but it was faster than entering a custom linetype manually.
Posted : May 21, 2013 7:18 pm
ladd-nelson
(@ladd-nelson)
Please feel free to send me your shape files and I'll work toward having them examined by the ITC programming team.
lnelsonATcarlsonswDOTcom
Posted : May 21, 2013 7:42 pm
D. Keith Kilby
(@d-k-kilby)
To my knowledge there is no way to make a shape file in intellicad: you will still have to use ACAD to make them and then move them into the intellicad support folders.
What I did was to copying my shape files into the Fonts folder under the Support folder in intellicad, then I renamed my acad line type file (*.lin) and placed/ copied it under the Support folder with the other line type files. You could also just modify the existing intellicad*. lin file. So far so good but I have only tested this on a few line types with simply shape files.
Posted : May 22, 2013 8:46 am
