I am making new cogo points like I always do, today all of a sudden the target buttons are not working. I tentative snap to the point I want but it does not pull the data into the NEZ fields. Maybe a setting got changed?? Any ideas?
Good luck with that. In the old days Bentley thought the world was E,N,Z so that is a setting. I've always been N,E,Z guy and I confuse easily. No more help from me.
But I did send you an email of a Microstation guru I've worked with for about 20 yrs. He's fixed up all my FUBAR's in the past. I'd post it here, but that's not quite right to try and hook you up with a fellow Red Wings fan 😉
cheers and best of luck there. And by all means, the new year is pending so take the best and move on.
w
What version InRoads?
There are several locks in InRoads. Sounds like you have point lock on, when you want graphic lock.
Lee Green
Thanks. microstation SS3 and inroads SS2. I think I have it figured out. Geopak was opening by default with the dgn, I turned it off and inroads works like it is supposed to.
