Help on Saturday??? Carlson LTSCALE.
7 Users
 ppm
(@ppm)
Working on a plat that, on one of the sheets, has details. There are some details at 1" = 30', one at 1" = 20', and one at 1" = 10'.
Everything is drawn in model space, of course. I cannot seem to remember for the life of me, how to set up my LTSCALE and PSLTSCALE.
Running Carlson 2015, on AutoCAD.
Posted : 16/04/2016 10:45 am
(@edward-reading)
Set both to 1
Posted : 16/04/2016 10:46 am
(@cptdent)
I usually set my LTSCALE to 0.5 and my PSLTSCALE to 0.
Posted : 16/04/2016 12:27 pm
(@cptdent)
Edward Reading, post: 367619, member: 132 wrote: Set both to 1
PSLTSCALE set to "1" means PSLTSCALE is turned OFF. A "0" PSLTSCALE means PSLTSCALE is turned ON.
Posted : 16/04/2016 3:33 pm
 vern
(@vern)
cptdent, post: 367670, member: 527 wrote: PSLTSCALE set to "1" means PSLTSCALE is turned OFF. A "0" PSLTSCALE means PSLTSCALE is turned ON.
I think you have that backwards, but one or zero will will work and the other won't.
Posted : 17/04/2016 5:49 am
Pull down menu...SETTINGS . DRAWING SETUP (maybe?)
Posted : 17/04/2016 10:48 am
(@john-putnam)
To have the viewport control the LTSCALE then PSLTSCALE needs to be set to 1 and TILEMODE need to be set to 0. Then the line type spacing is the same no matter what scale the viewport is at.
Posted : 17/04/2016 12:38 pm
(@edward-reading)
The PSLTSCALE system variable controls the linetype scaling of objects displayed in paper space
viewports.
0 = No special linetype scaling
1 = Viewport scaling governs linetype scaling
Posted : 17/04/2016 2:03 pm
(@cptdent)
vern, post: 367724, member: 3436 wrote: I think you have that backwards, but one or zero will will work and the other won't.
PSLTSCALE.docx (116.5 KB)
Posted : 17/04/2016 3:37 pm
(@lanceboyle93101)
PSLTSCALE=0 (off)
LTSCALE= drawing scale (some prefer at half the dwg. scale)
TILEMODE=0 (always. otherwise Paper Space no workie)
Posted : 23/04/2016 5:17 pm
