For whatever reason, my F2 button now functions as "Zoom Extents". I don't know how that happened, but I'd like to get it back to function as the open Text Window key.
I've Googled it with no useable results. It's been so long since I changed any function keys. Any ideas?
Seems to me that would be buried in the options menu, perhaps on the same tab as the mouse options
TRY
Options -> User Preferences, make sure the Windows standard accelerator keys are enabled under Windows Standard Behavior.
and of course with all things in windows try a reboot, it less now than in the "old days", but sometimes still works.
http://www.ellenfinkelstein.com/acadblog/create-a-custom-keyboard-shortcut/
http://www.ellenfinkelstein.com/acadblog/work-faster-with-autocad-keyboard-shortcuts/
Call me out of control, but here's the second page for all you Cadders:
Keyboard shortcuts can make your work go much faster. You can use the default keyboard shortcuts and create your own.
Here are the defaults that come with AutoCAD:
F1: Displays Help
F2: Toggles the Text Window
F3: Toggles OSNAP
F4: Toggles Tablet mode
F5: Toggles ISOPLANE
F6: Toggles Dynamic UCS
F7: Toggles GRID mode
F8: Toggles ORTHO mode
F9: Toggles SNAP mode
F10: Toggles Polar Tracking
F11: Toggles Object Snap Tracking
F12: Toggles Dynamic Input
CTRL+0: Toggles Clean Screen
CTRL+1: Toggles the Properties palette
CTRL+2: Toggles the DesignCenter palette
CTRL+3: Toggles the Tool Palettes Window
CTRL+4: Toggles the Sheet Set Manager
CTRL+6: Toggles the dbConnect Manager
CTRL+7: Toggles the Markup Set Manager
CTRL+8: Toggles the QuickCalc calculator palette
CTRL+9: Toggles the command window
CTRL+A: Selects all objects in the drawing
CTRL+SHIFT+A: Toggles Groups
CTRL+B: Toggles Snap mode
CTRL+C: Copies objects to Clipboard
CTRL+SHIFT+C: Copies objects to Clipboard with Base Point
CTRL+D: Toggles Dynamic UCS
CTRL+E: Cycles through isometric planes
CTRL+F: Toggles running object snaps
CTRL+G: Toggles the grid
CTRL+H: Toggles PICKSTYLE
CTRL+I: Toggles COORDS
CTRL+J; CTRL+M: Repeats the last command (pressing Enter does the same)
CTRL+L: Toggles Ortho mode
CTRL+N: Creates a new drawing
CTRL+O: Opens an existing drawing
CTRL+P: Prints/plots thecurrent drawing
CTRL+R: Cycles through layout viewports
CTRL+S: Saves the current drawing
CTRL+SHIFT+S: Opens the Save As dialog box
CTRL+T: Toggles TABLET mode
CTRL+V: Pastes data from the Clipboard
CTRL+SHIFT+V: Pastes data from the Clipboard as a Block
CTRL+X: Cuts objects to Clipboard
CTRL+Y: Cancels the preceding Undo action
CTRL+Z: Reverses the last action
CTRL+[; CTRL+: Cancels the current command (pressing Esc does the same)
CTRL+PAGE UP: Moves to the next layout tab to the left of the current tab
CTRL+PAGE DOWN: Moves to the next layout tab to the right of the current tab
ALT+F11: Displays the Visual Basic Editor
ALT+F8: Displays the Macros dialog box
You can create your own keyboard shortcuts. See my tip, “Create a custom keyboard shortcut” for the detailed steps.
Is anybody still using a tablet?
How antiquated is that?
You forgot Alt-Tab: switch windows when boss comes by.
This is my setup:
***ACCELERATORS
[F1]qsave
[F3]_node
[F4]_mid
[F5]_endp
[F6]_appint
[F7]_nea
[F9]_cen
[F10]_per
[F11]_ins
[F12]-layer
Do you have an F Lock button on your keyboard?
I had the same type of problem with no viable solution except for the simplest one.
Toggling the little F Lock Key on my New Microsoft Keyboard that I never realized existed.
That little bugger caused me weeks of frustration trying to figure out how to fix, what I thought was a corruption of my "cui" file. Turns out once I toggled that back on my F keys returned to their intended autocad shortcut functionality.
If that's not it and its a true change to your cui, then I may have some literature on a solution somewhere.
