Please help!
Some of the contours, but not all, in a topo I have "LIST" as zero elevation, when they should be over 5,000.
How do I convert a polyline in acad to have an elevation?
Thanks in advance for your help.
what software , what version ?
Select a contour, open Properties and change the elevation to the correct value.
Polylines have elevations. Sometimes that elevation is zero. Just double click on the polyline and the properties dialogue box will pop up. Change the elevation parameter from zero to what you want it to be.
Alternatively, you could use the MOVE command to move the polyline from 0,0,0 to 0,0,z - where z is the desired elevation.
this is working! thanks as always for the rescue!
Be careful using the MOVE command for this purpose. The current OSNAP setting and drawing conditions could produce undesired results. Changing the elevation using the properties dialog is safer.
As I recall, that can be shortcut to
MOVE @0,0,N
Where N is your vertical displacement.
Hopefully clients aren't being billed hourly for these less than optimal methods.
Here's one example of automation produced a long time ago.
