Deleteing Civill 3d layers
9 Users
(@johnymal)
Reputable Member Registered
As the title says, I am trying to delete some layers in civil 3d but the program refuses how can I force it to delete them?
ερωτημα cicill
Posted : 08/07/2022 11:16 pm
Illustrious Member Registered
Layers will not delete for the reasons listed in the dialogue box, plus, with C3d, when they are used in some style or setting. ?ÿHappy Hunting.
Posted : 09/07/2022 12:03 am
(@johnymal)
@norman-oklahoma The drawing has only some lines there is no way to force to delete? Crazy.
Posted : 09/07/2022 12:23 am
(@jitterboogie)
Famed Member Customer
@johnymal?ÿ
The C3D onion is nearly endless.?ÿ Unlike life, which is finite.
Good luck!
Posted : 09/07/2022 3:06 am
(@blitzkriegbob)
Yes there is a way to delete them. As stated by Mr. Oklahoma, you need to find their occurrences and delete them. The first thing I would check, based on your image, is my Object Layers tab within my drawing settings. If any of those are pointing to one of your offending layers, set it to layer 0 instead. If you did find any, do a purge at this point. You may or may not clear any out, but the fewer you have to hunt down from this point the better.
Next, you will need to check your styles for references to these layers. If you find references within an unused style, you may be able to delete that style. If you can not delete it, you will need to modify the reference to a different layer. Be aware that you may find it in more than one style, so you may not be able to purge it immediately. I would run a purge each time to see if I was successful. You will need to keep repeating the process until you are able to purge the layers. You will also need to run audits as you do this because you will be creating errors in your drawing.
If you are serious about wanting to do this, there might be a shortcut or two that I could recommend. Let me know if you are interested and I will share.
I will share that I believe having a good clean template (or preferably templates) will help with this in the future. For my work flow, I have multiple templates. For example, I like having an alignment template, a pipe network template, a profile template, a cross section template, etc. In each of these I will only have styles that are relevant to the drawing, and I will only have layers, and set object layers, that are relevant. I also have a master template that has everything, so if for some reason I find myself needing a style or layer, I can quickly drag it in from the master template.
I know it seems like a lot, but for an OCD guy like me, it works.?ÿ
Posted : 09/07/2022 4:40 am
(@john-putnam)
Noble Member Customer
After running the standard 'purge' command, go to C3D's 'manage' tab and use the 'styles purge' to remove any unused styles (it may take a couple of runs).?ÿ The run the standard purge again.?ÿ This should make your search for layers used by various styles a little easier.
Posted : 09/07/2022 6:13 am
(@johnymal)
@john-putnam And where I can find ''manage tab'' ?
Posted : 09/07/2022 6:34 am
(@bobwesterman)
Posted by: @johnymal
The manage tab is on the ribbon.
Mine is third from the left.
You could also just type PURGESTYLES
This is regular practice for me.?ÿ I always clean things up before sending out files.?ÿ
There is also a free app in the autdesk app store call superpurge which will remove a lot of other unused objects like arx objects dgn objects etc.?ÿ
Posted : 09/07/2022 6:53 am
AD818CCC B5EF 4375 96D2 B601AA605F5B
70D07C65 685E 4E25 A601 6B63AD526D38
What is this word?
5E848533 F66A 48C2 AE97 9B6892528E11
Posted : 09/07/2022 12:40 pm
(@antcrook)
Reputable Member Customer
Try "LAYDEL" then choose "N" for name, then select the layer you want to delete.
Posted : 09/07/2022 1:11 pm
(@jitterboogie)
__purge
PurgeLegacy
Audit.
Purge.
Audit.
Happy.
Posted : 09/07/2022 3:09 pm
(@robertusa)
You need to delete unneeded styles ?ÿthat have the layers in question listed in styles.?ÿ
Posted : 09/07/2022 4:45 pm
Share:
