Software, CAD & Mapping
2
Posts
2
Users
0
Reactions
1,187
Views
Hello guys,
I am trying to figure out a way to get my Code Library from Carlson into my MAGNET software that on my data collector. Carlson uses a .fcl file and Topcon's MAGNET uses a .xml file. I need a way to convert the .fcl into a .xml in order to collect data in MAGNET using my code list I have in Carlson. If anyone has and knowledge about this or any suggestions it would be much appreciated.
Thanks,
Bradley
Posted : January 12, 2015 12:26 am
1. create a dummy job in Magnet on the controller.
2. load the FCL onto the controller and import it into the dummy job.
3. under import/export you'll see Code List or Point Code or something to that affect; select FCL and import.
4. Export the recently imported codes to the Topcon XML format.
Posted : January 14, 2015 12:38 am
